Switch USB device between two PCs?
AlbertHall
Joined Jun 4, 2014
12,651
Does anyone know of any problem with using a DPDT relay to switch USB receiver part of a 'wireless desktop' (mouse/keyboard) between two computers.
The USB power from the PCs would be combined with schottky diodes (or possibly MOSFET 'perfect diodes') to power the USB receiver, relay and the circuit driving the relay.
wayneh
Joined Sep 9, 2010
18,136
I wouldn't connect the grounds of the two USB power supplies unless/until you can verify that no current will flow from one to the other. I'd start with a 1K resistor between the two grounds and look for a voltage across it. Drop it to 100Ω and repeat.
AlbertHall
Joined Jun 4, 2014
12,651
Good point. I will have to check that.
