Hello All,
I would like to switch between two power sources, namely solar panel 50 ~ 100W (variable power) and wind turbine 50 ~ 100W (variable power) , but max power in the system take 100W .
for example1:
Solar =80W
Wind turbine =20W
Solar + WT = 100w
for example 2:
Solar = 90W
WT= 40W
Solar +WT =130W
But the system work in max power 100W, is mean drop power from 130W to 100W
for example 3:
Solar = 50W
WT =70W
Solar + WT =120w
But the system work in max power 100W, is mean drop power from 120W to 100W
Is there any circuit to do this ?
for example1:
Solar =80W
Wind turbine =20W
Solar + WT = 100w
for example 2:
Solar = 90W
WT= 40W
Solar +WT =130W
for example 3:
Solar = 50W
WT =70W
Solar + WT =120w
