Superposition Question Help
Ronny2412
Joined Sep 2, 2014
17
Hello!
So, this is a question I received for my Homework & I decided to tackle it using Superposition Theorem.
1)
Firstly they have asked to find out Voltage at B with respect to GND.
In this case, 1st I ignore V2
Considering V1, I calculate the Voltage @ B wrt GND which turns out to be I*(R1+R2)
To Calculate I: I take V1/(R1+R2+R3+R4)
I then repeat the above step ignoring V1.
Finally Vb wrt GND= V1st step-V2nd step.
PLEASE LET ME KNOW IF THIS IS CORRECT
2)
Secondly they ask me to find out Voltage between A&B
I ignore V2.
Considering V1:
I used Voltage divider rule to get Vab= V1*(R2/R).
I then ignore V1 and repeat the step.
Finally Vab=V1st step-V2nd step.
PLEASE LET ME KNOW IF THIS IS CORRECT.
Thank you
Jony130
Joined Feb 17, 2009
5,600
I * (R1 + R2) is equal to a voltage drop across R1 + R2, but this is not Vb voltage.
In this step V1step = I * (R? + R?)
OK
Why you put a "minus" sign ?
I ignore V2.
Considering V1:
Again why "minus" sign. And are your sure that you need all this steps ?
In part A you already find the current, so Vab = I * R2
Ronny2412
Joined Sep 2, 2014
17
Dear Jony,
Thank you so much for your time.
Can you please explain to me where I am going wrong when I calculate Vb wrt GND?
anhnha
Joined Apr 19, 2012
904
It is OK to use superposition method here but honestly I don't like that approach much!
You just need to find the current I = (V2 - V1)/(R1 + R2 + R3 + R4) and then everything is simple to calculate.
Ronny2412
Joined Sep 2, 2014
17
I don't think you understand how superposition aproach works.
Let me ask a couple of questions.
Ok. So we are doing superposition in a circuit that has two independent voltage sources. We start with V1. You said to ignore V2. What do you mean by ingnore? Do you mean to replace it with a short circuit? Do you mean to replace it with an open circuit?
I meant we short circuit V2. .
Ronny2412
Joined Sep 2, 2014
17
Yes. I got that. I calculated Vb wrt ground across R3 & R4. I used Voltage Divider Rule to arrive to the formula:
Vb= V1* (R3+R4)/(R1+R2+R3+R4).
Is this correct?
Also, we did this by shorting V2. Shouldn't we then Short V1 & do the whole process again with V2?
MikeML
5,444
Here are the steps: Step 1 Set V1=0V, and solve.
Step 2: Set V2=0V and solve.
Now add V(b) in step 1 to V(b) in step 2 to get 4.2+3.6 = 7.8V
Here is the full solution, all at once, with V1 and V2 as specified:
Note that V(b) = 7.8V, as expected.
