Superconductors
The slightly more than lay level quantum explanation of type I superconductivity is pretty simple. That's good because it's the only way I understand it.
No collisions of charge carriers means no losses. The structure (altered by temperature combined with the internal lattice of the material) of the superconductor (clean superconducting simple metal) effectively creates a single-particle energy state in the entire mass of the superconductor by having a Coherence length (analogous to electron mean free path) for charge carriers that's smaller than the collision path/scattering time. The analogy at the quantum level is conductor slices of single thickness quantum particles (wave-functions) in the XY plane moving in the Z direction all in lock-step phase and frequency.
Quantum coherence
Regarding the occurrence of quantum coherence at a macroscopic level, it is interesting to note that the classical electromagnetic field exhibits macroscopic quantum coherence. The most obvious example is the carrier signal for radio and TV.
WBahn
Joined Mar 31, 2012
32,893
IIRC (it's been over a quarter century since I worked, as an undergrad, at NIST in the Superconductor and Magnetic Measurements Group) one way to view electron-pairing in Type I superconductors is that the so-called cooper pairs are created via phonon exchange. As a result, when one electron in the pair is "scattered" by some interaction the other electron in the pair, via phonon exchange, is scattered in exactly the opposite way. The result is that the pair, overall, is not affected.
https://arxiv.org/pdf/1906.00708.pdf
We observed zero electrical resistance near room temperature (T = 240 - 275 K) in one of the AuAg nanostructured thin films deposited on SiO2/Si substrate. The variation in transition temperature upon cooling and heating cycles and inconsistence dependence of transition temperature on magnetic field on our measurements do not support the clean superconducting behavior. This might be due to the instability issues associated with Au-Ag thin films during multiple heating-cooling cycles. The observed transition to zero resistance, albeit shown in one of the films only, is quite remarkable and requires more investigations on similar system. The present investigation along with previous report by Thapa et al. suggests the presence of an exotic and hidden superconducting like phase in Au-Ag nanostructures. The observed issues of instability and reproducibility may be associated with structure, lattice dynamics and/or spatial and compositional variations of Ag and Au nanoparticles in these systems. Further studies are required to better control the samples quality and understand the nature and origin of SC in these systems to harness the long awaited technological applications.
Only in one sample but certainly very interesting if it turns out to be correct.
Wendy
Joined Mar 24, 2008
23,798
While it isn't science I firmly believe their will be a room temp superconductor someday, as nothing in science forbids it.
Cool. One thing to remember is that even with room temperature superconductors it will still take enormous amounts of power to do the things we want to do using superconductors. The reduction in equivalent mechanical effort for cryogenic cooling is significant but for most heavy jobs that's only a fraction of the total effort needed for the task. National-level electrical transmission losses were under 10% of the total electricity disposition. So we might get half of that 10% back as superconductor savings if they were cheap and available as copper and aluminium wires.
ZCochran98
Joined Jul 24, 2018
351
Room Temperature Superconductor?
Exciting stuff. This could be the beginning of a major breakthrough.
Inches forward in a mile long destination.
https://www.forbes.com/sites/starts...-temperature-superconductors/?sh=4e90a87b8665
Recent developments have brought about the highest-temperature superconductor ever discovered, but we probably won’t be transforming our electronics infrastructure anytime soon. Here’s the science of what’s going on at the frontiers.
MrAl
Joined Jun 17, 2014
13,711
Yes there have been some interesting advances in superconductors. But there have also been big advances in quantum computers, understanding the quantum realm, quantum sensors, astrophysics, what 'space' is made up of, a large 'bullet' (100mm caliber) that can pierce through 10 plates of 6 inch steel, and one of my recent favorites: a jet that can go at 4200 mph using a new engine design. Of course i think my favorite of the year is Muskies rocket landing where it turns around, rocket engines fire, it slowly moves toward the ground when four landing 'arms' hinge out and down, then it lands softly on the ground. There is a video online i recommend seeing it's amazing.
Oh yeah, and dual layer solar cells.
I hear about advances in superconductors now and then. Havent seen any for sale yet though :)
ZCochran98
Joined Jul 24, 2018
351
I got the notification and couldn't resist; I figured you probably were referring to the room temperature ones, but couldn't resist being a little snarky. If it didn't cost buying nitrogen every time I wanted to do stuff with YBCO, I'd be halfway tempted to buy or make one of the "high-temperature" superconductors myself.
At least we don't need liquid helium anymore. That stuff can get expensive.
Wendy
Joined Mar 24, 2008
23,798
Dry ice would also be more affordable.
-109°F or -78°C I love Google and Alexa.
ZCochran98
Joined Jul 24, 2018
351
Alas, dry ice isn't cold enough for YBCO - it needs 90 K (-183 C), roughly. Dry ice would be sufficient for H2S (203 K, or -70 C), but that superconducts at 100 GPa pressure.
Edit: The 15 C superconductor is a combination of H2S and CH4, btw (267 GPa).
