Supercapacitor ameparage
Shayan Meh
Joined May 25, 2018
Hi
I have 5 farad 2.7 supercapacitor
what is the minimum ameparage needed to start charging ?
because when i use a 1.5 v battery it starts charging but when i use a 2.5 volt solar panel nothing happen
Externet
Joined Nov 29, 2005
2,631
The minimum charge current is the supercapacitor self-discharge or leakage current.
The charging time 't' to 63% is another story.
t=VC/I
V= 2.5
C = 5F
I = charging current minus leakage current.
DECELL
Joined Apr 23, 2018
96
Please check your connections.
Arrrgh! Eurrrgh? Oh that's my amapeRAGE gland bursting again!
Any current will do: CV =IT more timage more volters.
bring back the neper!
OBW0549
Joined Mar 2, 2015
3,566
This omits a vital fact: the capacitor's leakage current is dependent on the voltage across it. At V = 0, leakage is ZERO. For small values of voltage (V << Vrated), the leakage current is relatively low; as V increases and approaches Vrated, it tends to increase dramatically.
Leakage current is NOT some sort of threshold which must be exceeded to begin charging the capacitor. Rather, it starts out at zero and increases non-linearly as the capacitor voltage builds up; and if the leakage current at any particular voltage exceeds the current capability of whatever is trying to charge the capacitor, charging simply slows down and eventually stops at that voltage.
The OP has said that when his supercap is connected to the solar cell array, "nothing happens." I take that to mean the capacitor is not charging at all, which rules out capacitor leakage as the culprit.
