Hi guys, everyone still here? I've been side tracked with LTO battery testing.I'm trying to reverse engineer a 2.7v shunt board that is a little more sophisticated than the normal 2 component design.
I can't draw it properly, as some parts are unknown. All numbers of active devices removed.
This is tentative layout. May be a mistake crept in. Still checking.
It seems the original design uses the 5a npn driver to disipate half the heat. 2p-4r7 resistors have been changed to lamp that draws 800ma @ 2.75v.
I'm trying to get saturation, with lamp doing all the work.
200 ohm (51k) base resistor saturates output npn but not the driver, which then runs hot.
I'm stuck with this basic circuit, as boards are cheaper than I can build.
Bottom two devices don't match pinout for 431reg, pnp, or darlington. The .8v drop from p1-p2 with test meter, should be a clue.
Anyone willing take a look at this?
