Suitable transistor
Wolf5824
Joined Aug 2, 2022
6
Hi everyone
I want to connect a 40khz transducer to a Power supply & control it with a transistor
But i want to connect the ground to the transducer through the transistor
& the transistor should be a high speed switching transistor that works with maximum of 5v or lower going to the base
What is the best transistor ?
dl324
Joined Mar 30, 2015
18,453
Welcome to AAC!
  1. Are you going to use the transistor as a switch?
  2. What is the transducer impedance and voltage?
  3. What is driving the transistor?
  4. What are the voltage levels?
  5. How fast do you plan to switch the transducer?
  6. Does it have to be a BJT?
38,734
Not enough info--
What is the transducer voltage?
What is the transducer current?
How fast do you want to turn it on and off?
Wolf5824
Joined Aug 2, 2022
6
Welcome to AAC!
To answer your questions
1-yes
2-12vdc ( SKU: BFL740-3 Ultrasonic Level Sensor) link( https://www.bellenviro.co.uk/ultrasonic-level-sensor-0-3-metre-range-4-20ma-24v-dc.html )
3-an arduino generating 40khz signal @ maximum voltage 5v
4-a 12vdc @ 1Amps maximum Will be switched on & off by the transistor
(the transistor will be connected to the ground & it will be connecting & disconnecting the ground lead to the transducer)
5-switching speed 40000 times a second (40khz)
6-any suitable transistor (maximum base voltage 5v +high speed switching 40khz)
Ian0
Joined Aug 7, 2020
13,248
That’s an ultrasonic level sensor, not an ultrasonic transducer. It needs a 12V DC supply. I suspect that if you switch it on and off 40000 times a second it’s not going to be too happy.
35,092
Agreed. Read the datasheet very carefully.
The unit can be ordered with different types of outputs:
Alternative Outputs on request: 0-5V, 0-10V, 0-20mA, 4-20mA(3-wire), RS485.
Wolf5824
Joined Aug 2, 2022
6
Need spec of transducer, power supply voltage and details of the required switching performance
Transducer specs 12vdc ( SKU: BFL740-3 Ultrasonic Level Sensor) link( https://www.bellenviro.co.uk/ultrasonic-level-sensor-0-3-metre-range-4-20ma-24v-dc.html )
12vdc power supply
40000 times a second switching speed
I'm connecting the transistor to the ground lead to protect it
May logic is ( by using the transistor to connect & disconnect the ground lead to the transducer
No current or voltage will be passing through the transducer so in this case it doesn't matter what current or voltage the transducer draws from the power supply)
am i correct?
ericgibbs
Joined Jan 29, 2010
21,551
hi Wolf,
The transducer in post #10 is NOT suitable for the 40kHz drive.
E
Ultrasonic Level Sensor 0-3 Metre Range
4-20mA (2 wire) - 12V DC Power
Accuracy +/- 0.5% F.S
300mm Deadband
Beam Angle 15º
IP67 Rating (IP68 Optional)
Operating Temp 0-50 ºC
M68x2 mm Thread
38K±10Khz Operating Frequency
PP Housing Construction
0.5M Flying Lead
Alternative Outputs on request: 0-5V,0-10V,0-20mA,4-20mA(3-wire),RS485
Danko
Joined Nov 22, 2017
2,231
So you are saying that this 2N2222 transistor is a suitable one?
Yes, it is suitable for 40 kHz, no current, no voltage.
Resistor R1 value changed because of connection to Arduino.
Are you using a simulator? What is it?
Simulator LTspice. Download from:
https://www.analog.com/en/design-center/design-tools-and-calculators/ltspice-simulator.html
MisterBill2
Joined Jan 23, 2018
28,125
The device is an analog output distance measuring system.
That is totally different from an ultrasonic transducer. Others have mentioned that but evidently been ignored.
So far all of the circuits shown will lead to the damage and destruction of a rather expensive item.
So as a fist step in getting a bit of worthwhile advice, let us know what the goal is intended for using some sort of ultrasonic device. Until that information is given, the only good advice is to STOP!!
It appears that the TS, claiming to be a "maker", does not understand any of the comments about the device not being what they wish it to be.
