Suggestions for a 24 hr. motion sensor to activate a siren alarm
Chitreano
Joined Aug 27, 2020
This is what I need:
  1. Suggestions for the purchase of a motion sensor.
  2. 110 volt motion sensor with 24 hour detection that will activate an external siren upon detection of motion in the room
  3. It will be mounted inside a 40 x 60 workshop
  4. I would like to wire it through a light switch for deactivation when I am entering the building & then switch it on to activate upon leaving.
  5. I have one currently installed but it has an 80 second test/activation mode which sets off the siren for 80 seconds upon switching it on. When I leave and switch the detector on I don't want to listen to 80 seconds of a loud siren before it self silences and resets to detection mode.
  6. I need a simple day and night motion sensor that will activate a siren when powered up & detecting motion.
  7. Thank you for your suggestions.
dl324
Joined Mar 30, 2015
18,524
Welcome to AAC!
I think it would be easier to use two sensors. One for the alarm and one for the light.
They sell light switches with motion detectors; though they're not infallible. You can wire any standalone IR sensor to trigger an alarm.
Chitreano
Joined Aug 27, 2020
To clarify, The switch I am referring to is hidden and will only serve to power up the motion sensor when I am not in the shop. Upon entering I can turn the sensor off and upon leaving I can turn it on via the hidden switch. My lighting system in on a totally different circuit.
djsfantasi
Joined Apr 11, 2010
9,237
Home Depot floodlight sensor with power switched by a regular household switch. The sensor module can be removed from the light sockets and mounted wherever you want. Plus, you get a free added feature. A panic alarm. Double flipping the switch turns on the power to the siren.
MrSoftware
Joined Oct 29, 2013
2,280
The only catch here is some of them turn the lights on for several (30-60?) seconds when you first turn them on. Maybe a secondary component, a time delay relay for the siren?
DickCappels
Joined Aug 21, 2008
10,661
In the 1970's I installed some ultrasonic motion detectors in some burglar alarm systems. Did not have many nuisance trips -just be careful to not have things like pets and curtains that can be blown by the wind/heater/airconditioner within the detector's field of view. That was just at the time pyroelectric sensors were coming into use.
Pyroelectric sensors can be useful but they don't detect motion.
