I am using SMD Wire to Board Header for high-speed (200Hz) communication (an accelerometer is connected through the header), which is attached below. This header basically uses PICO-Lock to hold.
But The problem with this header is that it is discontinuous when the wires connected with the header are moved (requirement of the application).
Size of the header: 15mm x 5mm. Size is major constraint on the PCB.
Kindly suggest me the header similar to this or a better technique to connect the wires with the board (can't do soldering).
http://uk.rs-online.com/web/p/pcb-h...3743D35343237313431267374613D3534323731343126
http://uk.rs-online.com/web/p/pcb-c...3743D33343231363936267374613D3334323136393626
