- Joined Jan 23, 2018
- 28,636
A fan alone will not provide any cooling.. To actually cool anything requires a heat transfer device of some variety. Mechanical systems using either a Peltier function device or a compressor/condenser/evaporator system are required for actual cooling.
OR, does a fan blow air over the "cold-side" of a single Peltier device, while a different fan moves a different stream of air past the "hot side" of the same device ??
Airflow past a cooled surface is how heat is removed from the cold side. How else would heat flow be made to happen????
