SUCCESS STORIES: Repair thermoelectric cooler
lreeves
Joined Jul 27, 2024
5
I'm a retired engineer who specialized in switch-mode power supply designs. Looking at the schematics, several capacitors should be specified as switching regulator rated, low ESR at high frequency caps (typically with a 100kHz rating).
The data that I found indicates that C20 and C21 (120 uF, 200 V) are appropriately specified. However the secondary side caps, C8, CA1 and C10 are not likely rated for switching regulator use. In particular, C8 is the filter for the power to U1 (TL494 switch-mode regulator control IC). Failure of C8, can be expected to cause multiple failure symptoms, including non-operation of fans, TEC modules and the front panel display. My wine fridge displays all these symptoms.
According to the component values, the TL494 switching frequency is 50 kHz, so all 3 caps, C8, CA1 and C10 need to be rated for 100 kHz ripple current.
I acquired a free non-operational Wine Enthusiast, dual zone, 16 bottle fridge that uses 2 of the power supply modules that have been discussed here, and they have both are failed. The supply voltage to U1 pin 12 is failed, indicating C8 failure. I placed an order with Digi-Key today for Nichicon UPW series SMPS rated caps to replace C8, CA1, and C10 in both boards.
I'll update on how it turns out.
lreeves
Joined Jul 27, 2024
5
Updates: My boards are the FX-101 model. The Portuguese schematic matches my boards.
I found the data sheet for C10, Aishi RR series 2200 uF, 16 V, and it is rated for 100 kHz ESR and ripple current; so its specs are good. C10 is used in the fan power circuit.
CA1 is used in the circuit for the temperature control NTC thermistors, so it's failure would likely cause loss of temperature control.
C8 is the filter for the switching regulator chip U1. It's failure would cause multiple issues because U1 is critical to the entire board operation.
I pulled C8 and CA1 on both my boards. C8 measured about 20 uF (instead of 47 uF), so it was degraded on both units. CA1 on both measured only 2 to 4 uF, instead of 47, so both are failed. These 47 uF caps are Aishi CD81 series and are NOT good for switching regulator filters (only
heaver
Joined Jul 30, 2024
Success Story!!!
Thanks for all the helpful advice here. My fix was quite complicated and involved a number of different components which I'll list out.
This is what I started out with; a NewAir AW-321ED dual-zone wine cooler. This unit has two controller boards, one for each zone, and four thermoelectric cooler units, two for each zone.
The cooler wasn't working at all so I started at the controller boards after confirming that I was getting ~110v from the mains to the boards themselves.
View attachment 185856 View attachment 185857
You can see on the massive amount of charring where the heat-sinks were. Looks like the transistors are toast.=
Off to DigiKey I go... Here is the cart if you need the parts in one place.
After replacing *all* the caps, fuses, transistors, and a diode, she fired right up... Then blew the 2.5A 250V fuse! Doh.
Following some other threads on this site I determined that it was most likely the rectifier dioder that was broken so off to Amazon for a replacement. Once installed she fired up and stayed up!
...however one of the cooling units wasn't happy so I ordered new peltier units and installed them. PROBLEM FIXED!
The last thing on my list was the fans - they were 80mm and super noisy, not to mention old and bound to fail. I found four new 120mm silent fans and screwed them directly into the cooler fins.
This unit is now completely silent when running. I can't distinguish if it's on or off even in the dead of night and is holding 55 degrees like a champ.
You can see here the old 80mm fan on the left, and the new 120mm fan on the right.
Thanks again for all the info on this fix!
Hi, any idea on what the inside fans look like in terms of size? Are they also 120mm? And would you want the stronger fan to be on the inside (not the outside) to avoid turbulence inside the radiator? (or does that not matter?)
heaver
Joined Jul 30, 2024
Success Story!!!
Apologies for the spam. I can't seem to be able to edit my post.
Did you use a 3 to 2 pin adapter? If so, was it 2.5mm or 2mm?
And you did not change the inside fans, correct?
Lastly, any idea on what is the model of the board? And is it interchangeable with the fx-101 and fx-102s you can find around for $25? Does the wattage need to match exactly? Or could I theoretically use a "stronger" one that would cool better?
35,325
Note that this thread is for SUCCESS STORIES only.
If you want helpers to focus on your specific problem you should start a new thread.
wayneh
Joined Sep 9, 2010
18,184
Here's the fan I used to replace the OEM. It's a good fan but in my case the higher profile was a problem.
https://www.amazon.com/gp/product/B0027T5WZU
That said, your fans are almost certainly different. You'll just have to pull the thing apart and take measurements, and hopefully find a label so you can look up the specs. You want to provide at least the original CFM but note that the CFM spec can be different depending on the details of the specifications. Average versus peak, that sort of thing. By and large if the fan fits and matches the electrical specs, it'll be fine. But it'd good to doublecheck.
lreeves
Joined Jul 27, 2024
5
I pulled C8 and CA1 on both my boards. C8 measured about 20 uF (instead of 47 uF), so it was degraded on both units. CA1 on both measured only 2 to 4 uF, instead of 47, so both are failed. These 47 uF caps are Aishi CD81 series and are NOT good for switching regulator filters (only 120Hz rated, for 83 mA).
It's working now. I replaced C8 and CA1 with SMPS rated caps, Nichicon UPW series 47 uF / 63 V, rated for up to 405 mA @100 kHz. The switching frequency is 34 kHz (68 kHz ripple frequency on the DC output voltages). But I found excessive ringing at 860 kHz on all the voltages because the U1 IC didn't have high frequency bypass caps as recommended in the TL494 datasheet. So I added 10 nF caps from Vcc and Vref pins to ground (pins 12 and 14 to pin 7) on the bottom side of the board. Now waveforms are clean. Both sides have cooled to 54 deg F in an ambient temp of 80 F.
fiery1
Joined Sep 6, 2024
My little under the desk beer fridge packed it again. WIth some simple diagnosing I also noticed that if I unplugged the TEG and powered the circuit, the fridge appeared to function, and continued to do so plugging the TEG in 'live'. About 6 years back C10 presented bloating about, so it was an obvious component that needed replacing then. This time however I was at odds where to begin, as everything 'looked' fine. It's amazing what one can find when delving into the 'internets'. Many thanks to lreeves into determining that both C8 and CA1 were potentially problematic. Presently I don't have adequate testing equipment, however there's an electronic components store a short walk from my place. Alas I had to buy a 10pack, but @ $1.20 in Canadian funds, it was essentially free. Out with the old and in with the new, I'm happy to report my little beer fridge is once again running smoothly as before. Thank you lreeves!
Ofirshw
Joined Dec 23, 2023
15
Yet another TEC wine cooler:
TL;DR:
Dead TEC and bad C8.
In detail:
I received from friends a non-functional 70W device, claiming that it ticks.
Checking at home it didn't really tick, but the TEC itself is dead as it takes no current. It had a much bigger TEC than I'm familiar with but with no identification, but luckily I had spare parts (TEC-12706 as it fits another 70W cooler of mine).
I put this one and then it had problems to power up.
The board inside is yet another version of FX-102 , it's PCB50418E1 HWREV 2.0. This is a 2008 made wine cooler, and it's very similar to the board of another one I have.
It looks VERY similar to this:
I noticed that the C10 which I replaced on another wine cooler had a wrong value, 1000uF instead of 2200uF, so I assumed that it was treated before by someone that didn't have the right parts. So first I put a new 2200uF instead, but it didn't solve the problem. I then noticed that when disconnecting FAN2 (CN2) the wine cooler starts pretty quickly, but when connecting FAN2 it has hard time to start, meaning that the LEDs lightly blink for 20-60 seconds before it starts, if at all. Time to look for a schematics.
I found its schematics online:
And surprisingly, there are versions of C10=1000uF! Well I already replaced it to a 2200uF as in a 2011 version so I'll keep it there.
The direct suspect now is C8, which is not really under load without FAN2 connected, but is under load with FAN2 connected.
Checking C8, it had reasonable capacitance(42uF), but it's ESR value was very high (>12ohm). So I replaced it with and new one and ..... the wine cooler starts without any problem!
Again thanks this forum for the great support and resources.
wayneh
Joined Sep 9, 2010
18,184
I wonder if someday we'll see an end to these stories, because the original design has been 'fixed'. Do you think the original designer(s) have any idea of the C8 issue?
wayneh
Joined Sep 9, 2010
18,184
Or is it planned obsolescence?
They get to sell more wine coolers.
In my recent experience, that's what thermal fuses are used for, at least in cheap appliances. The appliance fails (safely) and the repair costs a significant portion of the cost of the appliance. These wine coolers are worth a bit more I suppose.
28,636
OK, it looks like C8 is a part of the extended power supply related to the fans, AND the supply voltages for other portions of the system. So checking it was a good call, and while high ESR is not always a performance killer, evidently it was in this instance. Good Detective work!!!
Firstly, thanks to all for the great information here! I'm very much an amateur and it really helped.
I have a VinoTemp, and while it doesn't (visually) look like the boards here, it appears to be a FX101.
I have had 2 C10 failures in the last three years. A quick switch got them working again.
35,325
C10 is the reservoir capacitor on the output of the SMPS. It is either 1000 μF or 2200 μF, 16 V or 25 V.
Definitely go with the higher voltage if the capacitor leads will match the solder pad/holes.
You might have better success going with the higher capacitance and voltage, i.e. 2200 μF / 25 V or even 50 V.
K6216
Joined Jul 23, 2017
21
Here is an update for those of you who encounter the FX100 power supply marked PCB100817F4. It is used in several Wine Enthusiast coolers including the dual door version with 2 supplies and 2 TEC units. Following a failure, I replaced all capacitors in both supplies and both primary switching transistors in one supply. (D13007K 400V NPN transistors). Now both are working fine for the next couple of years!
Dont screw around by replacing 1 or 2 caps that may look bad. If even 1 is suspect, they all are crap and need replacing. You may get by without replacing the 2 primary reservoir capacitors.Wine Cooler FX100-1.jpg
28,636
Certainly some capacitor brands during some time periods have earned a poor reputation, and replacing them was quite standard, and the repair success for the replacement was an indication of the validity of the poor reputation. I have not seen a mention of the particular brand of the capacitors that get replaced, but the color scheme matches the brand that got replaced in both Sony and Superscope products back in the mid seventies. Could it be the same quality issue with the same brand fifty years later??? OR, could it be that some purchasing agent found a great price deal on parts that had been on the shelves for a lot of years?? We can only guess.
wayneh
Joined Sep 9, 2010
18,184
See my post #11.
"Most of the capacitors on the PCB are labelled CD81 and manufactured by Aishi."
But I don't think that's true for everyone else that has reported here.
SgtWookie Off-Topic 4
