Subwoofer magnet warm?
PaPiャSly
Joined Dec 25, 2022
47
is it normal for subwoofer magnet to get warm? played for about 30min with somewhat high bass and when i touched the cone it was warm so i removed it and checked the magnet it felt warm not that hot but really warm so i was woried since if the magnet was that warm how warm would the coil be.
ronsimpson
Joined Oct 7, 2019
4,795
Some of the large speaker/ driver/ magnets I have used have heat sink fins to cool them off.
When things heat up the size changes and will not work the same.
"Warm" is not well defined but expected.
28,125
Adding to what AD A explained, the efficiency of a standard speaker [s very low, less than 10% for the best trumpet/horn speakers that sound really terrible for music. So playing at 100 watts will give you 90 watts of heat, and that will make a magnet quite warm after a while.
LowQCab
Joined Nov 6, 2012
5,102
Speakers are "Impedance-Transformers",
and there is usually a hideous "Impedance-mismatch" between
the average "Direct-Radiator" type Speaker and the surrounding Air.
This is what causes the gross inefficiencies in most Speakers.
Inefficiency = Heat.
Properly designed Horns can easily have ~30% or better efficiency,
and are amongst the highest Fidelity Speakers available.
This is because they have a "better" "Impedance-Match" with the Air.
Most "high-end" Speakers have Horn-Loaded-Tweeters.
The only reason they don't have Horn-Loaded-Mid-Ranges as well
is because of physical size requirements for a properly designed Mid-Range-Horn.
A properly designed Horn must be at least 1-Wavelength long at the
lowest Frequency that it is expected to reproduce,
and,
the Circumference of the Horn-Mouth must also be at least 1-Wavelength at the lowest-Frequency.
( Rectangular-Mouth-Horns have a special formula for calculating the minimum dimensions ).
( If these rules are not followed,
the horn will "Honk" at certain Frequencies,
( yes, "Honk" the "official" term for what poorly designed Horns do ),
and they may possibly resonate at multiples of those Frequencies as well ).
Compromised-Designs, or "gimmick" Horns, can sometimes sound really, really bad.
The JBL-Corp. knows what they are doing,
and they've been doing it really well, for well over ~50-years,
and all of their big "Professional" Speakers have both
Horn-Loaded Mid-Ranges and Horn-Loaded Tweeters.
28,125
Obviously we are talking about different kinds of horn speakers. I am talking about those aluminum re-entrant trumpet speakers that are used for cheap PA systems in some businesses, that can not reproduce any frequency below 350 H or so, and then somebody wants to play violin music through them. It seems like LQC is thinking of those very large wooden corner speakers that provide a sound path quite a few feet long, and can actually reproduce below 60Hz. Two totally different animals, although the same principle .
38,737
The old Altec-Lansing Voice-of-the-Theater speakers used a horn midrange-tweeter, and a horn-loaded woofer for the high efficiency needed to provide sufficient sound volume for movie theaters with the relatively low-power, vacuum-tube amplifiers available at the time.
28,125
NONE of those were the tinny sounding short and small trumpets that would fit into a 7 inch cube, and had a cutoff of about 400 Hz.
