Substituting Silicon transistors for Germanium
Status
Not open for further replies.
MountainGuy
Joined Jan 15, 2017
36
I was wondering if anyone could help me locate a way to find substitutions for the following germanium transistors. I'd like to convert a circuit to silicon if possible. I have SK3009, 2N2428 and 2N2431 transistors. Any help would be appreciated. Thanks.
Dodgydave
Joined Jun 22, 2012
11,395
Your problem will be the base bias for the transistors, Germanium is 200mV, whereas Silicon is 700mV, do you have a circuit diagram?
ian field
Joined Oct 27, 2012
6,536
With split secondary audio driver transformers - its too easy. Most had simple resistor divider for each base bias, but using a bias diode of the appropriate material was a worthwhile improvement - especially if you gave the diode thermal contact with the transistor heat sink.
There are a few general circuits that accommodate the same modification, but usually the bias divider needs to be re calculated.
Germanium transistors were usually seriously leaky - silicon; not so much. Once or twice I've had to change the resistor in the emitter self bias network to trim the operating point.
MrAl
Joined Jun 17, 2014
13,913
One of the main concerns here is the operating voltage. If this runs off of a 1.5v battery then it maybe hard to get it to work properly with silicon unless the circuit does not have to start up at a very low voltage. Sometimes it works sometimes it doesnt.
Back about 10 years ago i suggested looking into using a germanium transistor for a boost converter that has to start up at a little as 0.5 volts DC. That was meant for consumers that wish to have their flashlights start up even with a very low battery in a critical application such as for a caving light (cave explorers above and below water). There are some problems that come up though, but then i read that there was research being done on hybrid transistors that are part germanium and part silicon. If they are on the market by now maybe you could check into that. Otherwise perhaps a germanium to start the circuit and then bootstrap to keep the circuit going.
ian field
Joined Oct 27, 2012
6,536
AFAICR: germanium devices have a higher dynamic resistance, Vf & VCEsat are a bit more elastic than silicon.
There's a German manufactured boost converter disguised as a SMD transistor - there was one free on a long back issue of Elektor magazine. Its primarily for single cell white LED applications and micropower PSUs. But it demonstrates sound principle. Its something like 0.7 or 0.9V minimum start up. Very foggy distant memory thinks its a PR4401 or something like that. Generally; blocking oscillator type Joule thief type circuits are the sort of thing that's easy to find.
MrAl
Joined Jun 17, 2014
13,913
Yes the germanium transistors have some undesirable qualities, but they can allow starting a boost converter even at 0.5 volts. Once the converter starts, the germanium transistor is no longer needed so it goes back to working on silicon. So it's used to start the circuit and then bootstrapping keeps it running without the need for the germanium transistor.
recklessrog
Joined May 23, 2013
985
In the early days of replacing Germanium transistors with Silicon, as a rule of thumb, was to double the value of the emitter resistor to bias them correctly. Works 9 times out of ten.
MountainGuy
Joined Jan 15, 2017
36
That would be worth trying. So I guess I could just try to get transistors that could handle the voltage and swap.
ian field
Joined Oct 27, 2012
6,536
If you're bootstrapping a silicon topology switcher - the most likely is a blocking oscillator Joule thief. They usually work better with no emitter resistor at all.
I made it in!!
Thanks!
I've been trying to substitute 2n466 (fried by me) with 2n4399 or NTE180 (I have these in stock)
in a 12v inverter oscillator circuit.This is a popular old CDI unit sold by several entities.
This is the one that starts with an H (model cee pee 1060) that is slightly different than the Delta unit that has the schematic identified and available.
After weeks of searching, I was able to identify the exact schematic posted online with no specific ID.
I have tested all the components, and found them to be sound. At one point, I was able to get the oscillator to function with the 2n4399 by fudging the E to B resistance, now I can't. Was never able to keep it running consistently since I fried the original germaniums.
I know that this circuit is really simple to someone more familiar with oscillators.
I would like to get this CDI unit working soon so I can use it in my 1962 Chev step van.
The circuit should provide 300vdc to the coil. It provides awesome spark when it's working...but I blew it up. The xfrmr is tested good with outboard oscillator and scope. Have been temped to drive it with a 555. Want to take the simplest, most reliable approach.
I made a jpg conversion that's a bit rough. Let me know if you need more details.
georgep
Joined Aug 6, 2017
TRY BGMicro.com
BGMicro Electronics PNP Germanium House Number, TO-3, Like 2N176, 2N256, 2N555,NTE104 And NTE121
Your Price: $1.56
BG Part Number: TRN1008
Si Carbide
Joined Jul 18, 2021
Recklessrog, pardon me, but I think you might be mis-remembering. Don't you mean "HALVE the value of the emitter resistor"?
Halving the emitter resistor allows the BE junction to drop 0.7V instead of 0.3, but still turn on. Of course, the stage gain would also about double (which could be a problem). A better method would be to recalculate and change one or both of the base resistors. See... http://www.hawestv.com/transistorize/germanium1.htm
I'm new to this forum. But I'll try to attach a schematic with an example of halving the emitter resistor in the silicon circuit. (CAUTION: These are untested circuits. But they look as though they might be worth checking on a breadboard. Circuit voltages are approximate.)
Status
