Substituting an LC with a crystal.
Antsy electron
Joined Dec 27, 2022
69
Please , see the figure below . Can I substitute the LC tank in this circuit with a crystal ( no crystal oscillator, just the xtal) ??. If so , do I have to add a capacitor in series with xtal or what changes do I have to do ?. Screenshot_20230117-135238.png
35,245
No, you cannot replace LC circuit with a crystal. The properties of a crystal and LC circuit are very different.
If you want a crystal controlled oscillator, you need a circuit designed for a crystal.
Antsy electron
Joined Dec 27, 2022
69
Here is an example of a crystal oscillator circuit.
What a coincidence, I did that one two days ago with a 4 mHz xtal and it worked as prescribed, however I don't know how to connect an audio source. I think I should put a coupling capacitor at the output of this oscillator and connected to base base of another npn with positive of the audio source to the collector and the transmitter to the ground of it .. Is that right ?.
