Substitute transistors for IC in analog video amplifier
spikespiegelbebop
Joined Nov 30, 2021
163
This is a simple analog video amplifier and I'm wondering which video amplifier IC could I use to substitute its transistors.
Input should be 0.7Vpp 75ohm video. Output is 4Vpp with about half a volt of DC offset added.
Application: Amplify SCART RGB signal coming out of a videogame console (Video amplitude: 0.7Vpp).
AnalogKid
Joined Aug 1, 2013
12,266
Inrersil, Linear Technology, Analog Devices, Maxim, and Texas Instruments all make (or used to make) triple video amplifier chips. However, a 4 Vpp output is not standard, so you would have to check the output compliance of the available chips.
Why is the output voltage requirement so high? Normally it would be 2 Vpp before an output terminator.
Are the input signals real analog video, or just square waves? Driving a monitor with a 4 V signal feels like the monitor is designed for TTL input signals.
ak
DickCappels
Joined Aug 21, 2008
10,661
I've been out of that business for over 20 years and don't have an idea of can be had today. Both Motorola (in the 1990's) and National Semiconductor made monolithic video amps. You might start there.
spikespiegelbebop
Joined Nov 30, 2021
163
Well, I'm once again out of time for this project. I'll leave it be for now and I'll be back when I have spare time. Is there any way for me to put this post in a favorites list or to-do list, something like that? If I just bookmark it, I'll forget it for sure. lol
