Subject of Code Tags.
jpanhalt
Joined Jan 18, 2008
11,087
I tried to get highlighting with no effect with [code=asm] <code>[/code]. Using the color icon, all it did was print the color code like this:
MPASM behaved the same. ASMPIC16 and variations of that simply gave "unknown code. " However, the "mono" tags do work as expected for color.
bertus
Joined Apr 5, 2008
22,994
As far as I know the language should be in lower case:
Code:
org     0x000
        goto    main
    org     0x004   ; interrupt vector location
        movwf   w_temp          ; save off current W register contents
        movf    STATUS, W        ; move status register into W register
        movwf   status_temp     ; save off contents of STATUS register
int_here:
               ;Identify source
        btfsc    INTCON, INTF    ;Ext P.B.?
         goto    ext_int
         btfsc    INTCON, T0IF    ;Ext TMR0?
         goto    t0_int
         goto    isr_end    ;Neither so go exit
ext_int:
        bcf        STATUS, RP0
Bertus
bertus
Joined Apr 5, 2008
22,994
I used the following to produce the code in post #3
[code=asm]
org 0x000
goto main
int_here:
;Identify source
goto ext_int
goto t0_int
ext_int:
bcf STATUS, RP0
[/code]
I see that the plain tag also removes the intends.
Bertus
jpanhalt
Joined Jan 18, 2008
11,087
With code=asm, I do not get highlighting for this, based on the preview window:
In ASM, literals are normally highlighted, but the movwf is not highlighted as intended:
JohnInTX
Joined Jun 26, 2012
4,787
Did you do the color highlighting in the code yourself? If so, the code tag parser doesn't like that. It would be nice if it did or at least ignored the brackets but I've had that problem myself.
FWIW you can use MPASM as the language ID for PIC. I think it's a little better.
bertus
Joined Apr 5, 2008
22,994
using mpasm
Code:
org     0x000
        goto    main
int_here:
               ;Identify source
         goto    ext_int
         goto    t0_int
ext_int:
        bcf        STATUS, RP0
Bertus
