Hi, how do you compute the strength of EMI that can clip 1mV signal from typical EKG, EMG and any standard biopotential measuring equipment? ?
Supposed the green sine wave is the 1mV signal. And the red sine wave is the EMI. What strength of the EMI before it can clip the 1mV signal such that the output (at bottom) would become distorted?
Supposed the green sine wave (top) is the 1mV signal. And the red sine wave is the RFI (radiated). What strength of the RFI before it can clip the 1mV signal such that the output (at bottom) would become distorted?
I'm talking of radiated RFI interference, not from EMI from power supply lines because I used batteries, so it is disconnected from main.
Also I most often see EMI filters to filter power lines. Can these be used also to filter radiated interferences?
