hi all, i want to ask u guys about something very strange happen in an analog multiplier IC , i have an anlog multiplier IC it works as a modulator has two input signal the carrier signal and the information signal and the output is modulation of them , when i connected the output to an oscilloscope i did't see any thing just random noise , but the strange thing when i accidentally connected the oscilloscope prob to the Vcc of the multiplier (+5v) the signal which appeared on the oscilloscope is the carrier signal !!! with the exact carrier frequency, how the carrier signal came out from the Vcc terminal or may be the IC is damaged ? (btw the IC has +5v ,-5v and ground pins) , i need an explanation plz
