Hello there, ingles is not my main language so apologies in advance.
Anyway, I was just fixing a regular old led bulb, you all know the gist, 1 led burned, jumper it and plug when I noticed that there was no rectifier ic on the pcb, there was only one smd that seem to serve both as rectifier and driver in a single package, found that curious so I tried searching for that little thing's datasheet on internet with no results at all, tried all the pages listed on the first post in this forum as well.
All I found about it was the pcb UL certificate with a manufacturer that doesn't exist (DEXUNDA ELECTRONIC TECHNOLOGY CO LTD), the model I have btw is the DXD-AL1, on the pictures attached is the ic and a birdview of the pcb, below it there's nothing, just metal for heat dissipation, no hidden smd.
The manufacturer of the ic driver seems to be JW, no idea what it stands for and I don't have the tools to reverse engineer it, if anyone can help finding the datasheet, thanks.
Forgot to add, it have 7 pins, strange distribution as well.
