Strange computer problem
Pfrrr
Joined Sep 13, 2017
Hi! I don't know if this is the right place for this question but I have one problem with my laptop that's driving me crazy. So, after some time my ThinkPad Yoga decided not to boot anymore. SSD was always visible from UEFI and after failing to boot (just black screen) it would always show bootloader with options to boot Windows or to boot from SSD but whether option I would have chosen it would always throw me back to boot selection. I tried everything I could think off on software side but nothing helped. So I started playing with motherboard and found a way to boot it. I was measuring voltages on SATA connector and found out that if I measure voltage across GND and B+(RXP) pin on signal connector and turn on laptop it would boot every time! And when it comes to Windows loading screen I could just disconnect voltmeter and everything would work fine. After that if laptop isn't turned off completely (it could go to sleep and resume with no problem) or restarted, it would work just fine. So my question is- any idea what's going on and where lays the problem? Problem only arises during boot and it can be fixed by measuring voltage across these two pins (voltmeter acts as a resistor?) for a few seconds.
joeyd999
Joined Jun 6, 2011
6,561
Possibly a surface mount pull-up/pull-down resistor was not soldered properly and broke free from the pad. Attach a large value resistor (>100K) between those two pins and see if that permanently solves the problem.
wayneh
Joined Sep 9, 2010
18,184
It resembles a problem with having a dead PRAM battery. If there’s a battery on the board, check it. @joeyd999 probably nailed it. I’m just throwing out another option if that falls.
