Strain gauge output amplification using LM358P
38,803
It gives me a change from 120 ohms to 120.3 - 120.4 ohms change
With 5V on the bridge and three 120 ohm bridge resistors (which give the maximum voltage change with change is resistance) the bridge voltage change is only about 4mV, so you will need a high-gain, low-drift amplifier to get a decent output signal.
AtomicFlea69
Joined Mar 23, 2022
18
@crutschow I actually use two 1k ohm resistors and one 120 ohm resistance along with the strain gauge. So does this setup too give a low voltage? If so, can you suggest me a good Op-Amp?
AtomicFlea69
Joined Mar 23, 2022
18
