I would use anti static foam so you can push the pins into it. Then pop in a plastic container.
N nigelwright7557 Joined May 10, 2008 532 Mar 24, 2015 #21 I would use anti static foam so you can push the pins into it. Then pop in a plastic container.
takao21203 Joined Apr 28, 2012 3,702 Mar 25, 2015 #22 For shipping no, you shouldnt use regular plastic. For storing its OK when you dont have static at your place. You can also check with paper, dust particles, tin foil strips, and so on.
