stm8s003 timer1 channel2 capture doesn't work
john137
Joined Oct 25, 2023
this doesn't work:
TIM1_CCMR2 = 0b01; //its default input channel
TIM1_IER = 0b100; //channel 2 capture interrupt
TIM1_CCER2 = 0b1; //channel 2 capture
TIM1_CR1 = 0b1; //start counter
and yet this works with no problem (on channel 1)
TIM1_CCMR1 = 0b10; //remap channel 1 on input 2 where ch2 is supposed to be by default
TIM1_IER = 0b10; //capture channel 1 interrupt
TIM1_CCER1 = 0b1; //enable channel 1 capture
also, if I remap channel one on ti 1 (pin 16) it still works (on channel one pin) but if I remap channel 2 on ti 1 it won't.
I need to get them both to work.
jeffl_2
Joined Sep 17, 2013
78
Are you programming this from a "complete" datasheet? I went on Digikey to look at the one they linked and at 103 pages it was pitifully small for a microcomputer datasheet, compare that to a Microchip PIC16F series at 400-500 pages. Naturally this meant they didn't have room to "spell out" the definitions AND uses/interactions of all of the 32 bytes/256 bits in the section dealing with TIM1, now I suspect the bits of the CAPCOM section are "kind of" similar to some of the aforementioned Microchip devices but I wouldn't guarantee anything. Unless you both know how ALL these bits are defined/used AND how they default at powerup (which ones HAVE TO be set/cleared before use in a certain mode) you aren't going to get anywhere. If you do have a link to the more complete version of this datasheet and post it we might be able to help you, but as is I suspect something isn't being initialized correctly for your use (and unlike Microchip designs there are some combinations of option/AFRs that are actually INCOMPATIBLE with each other so you have to watch out for that as well). Sorry I can't help you more at this time.
35,278
You looked at the datasheet, not the RM0016 Reference Manual which is 467 pages.
35,278
this doesn't work:
This part is wrong.
TIM1_CCER1 is for channels 1 and 2.
TIM1_CCER2 is for channels 3 and 4.
What you need is this:
TIM1_CCER1 = 0b00010001; //channels 1 and 2 capture enable
Here is the link to the Reference Manual:
https://www.st.com/resource/en/refe...-8bit-microcontrollers-stmicroelectronics.pdf
jeffl_2
Joined Sep 17, 2013
78
You're right, because that's what Microchip (what I'm used to) links to on Digikey. But even a "dumbed-down" datasheet OUGHT to include sufficient detail to show all the relevant control bits, just maybe leave off the space-hungry diagrams and descriptions. Maybe that's why ST parts aren't nearly as popular, they don't make it as easy to find all the needed info.
