Good afternoon, dear collegs!
I'v started to connect STM32H7 (Cortex M7) MCU with exteranal Nor-Flash memory by use FMC. I'm alittle confused by write command. Without DSB() command it refuses to work correct. Program loads from embedded Flash (7 waitstaits).
Doesn't work (C):
(Asm):
Work correct (C):
(Asm):
Can anyboady explain me why it work so? Why we need to wait execution of all previous instructions before storing new data in new address? On STM32F4 (Cortex-M4) it works without DSB command.
What time (CPU cycles) does instruction STR takes? RM of ARM v7 gives 2 N-cyles. But what does it means in CPU cylces I don't understand.
I'll be glad to any help!
Doesn't work (C):
Code:
*(__IO uint16_t *)((uint32_t)(__ADDRESS__)) = (__DATA__);
Code:
MOVS r0,#0xF0
STRH r0,[r4,#0xAAA]
(next instuction)
Code:
__DSB();
Code:
MOVS r0,#0xF0
STRH r0,[r4,#0xAAA]
NOP
NOP
NOP
DSB.W
NOP
NOP
NOP
NOP
(next instuction)
