STM32F4 - Radiolink SE100 GPS
StellWalker
Joined Dec 12, 2016
7
Hi. I am using STM32F407VGT6 this one and RadioLink SE100 GPS. I am trying to get $GNGGA data via USART and displaying it in putty terminal. I am able to get and print data. After 3-4 minutes gps sensor led is blinking but no data is printed on terminal.
Here is my code:
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * <h2><center>&copy; Copyright (c) 2021 STMicroelectronics.
  * All rights reserved.</center></h2>
  * This software component is licensed by ST under BSD 3-Clause license,
  * the "License"; You may not use this file except in compliance with the
  * License. You may obtain a copy of the License at:
  *                        opensource.org/licenses/BSD-3-Clause
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#include "string.h"
#include "stdlib.h"
#include "stdio.h"
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
uint8_t flag = 0;
// this interrupts changes flag to 1 as soon as the uint8_t buff[300] is full
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart) {
    flag = 1;
// function to calculate checksum of the NMEA sentence
// -4, but not -3 because the NMEA sentences are delimited with \r\n, and there also is the invisible \r in the end
int nmea0183_checksum(char *msg) {
    int checksum = 0;
    int j = 0;
    // the first $ sign and the last two bytes of original CRC + the * sign
    for (j = 1; j < strlen(msg) - 4; j++) {
        checksum = checksum ^ (unsigned) msg[j];
    return checksum;
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
UART_HandleTypeDef huart1;
UART_HandleTypeDef huart2;
DMA_HandleTypeDef hdma_usart1_rx;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_DMA_Init(void);
static void MX_USART1_UART_Init(void);
static void MX_USART2_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_USART1_UART_Init();
  MX_USART2_UART_Init();
  /* USER CODE BEGIN 2 */
  uint8_t buff[255];
  char buffStr[255];
  char nmeaSnt[80];
  char *rawSum;
  char smNmbr[3];
  char *latRaw;
  char latDg[2];
  char latMS[7];
  char *hemNS;
  char *lonRaw;
  char lonDg[3];
  char lonMS[7];
  char *hemEW;
  char *utcRaw;
  char strUTC[8];
  char hH[2];
  char mM[2];
  char sS[2];
  uint8_t cnt = 0;
  HAL_UART_Receive_DMA(&huart1, buff, 255);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
      if (flag == 1) {
          memset(buffStr, 0, 255);
          sprintf(buffStr, "%s", buff);
          //HAL_UART_Transmit(&huart2, buff, 255,70);
          char *token, *string;
          string = strdup(buffStr);
          while ((token = strsep(&string, "\n")) != NULL) {
              memset(nmeaSnt, 0, 80);
              sprintf(nmeaSnt, "%s", token);
              if ((strstr(nmeaSnt, "$GNGGA") != 0) && strlen(nmeaSnt) > 73 && strstr(nmeaSnt, "*") != 0) {
                  rawSum = strstr(nmeaSnt, "*");
                  memcpy(smNmbr, &rawSum[1], 2);
                  smNmbr[2] = '\0';
                  uint8_t intSum = nmea0183_checksum(nmeaSnt);
                  char hex[2];
                  sprintf(hex, "%X", intSum);
                  if (strstr(smNmbr, hex) != NULL) {
                      //if we want display good $GNGLL NMEA sentences
                      HAL_UART_Transmit(&huart2, nmeaSnt, 74, 90);
                      HAL_UART_Transmit(&huart2, (uint8_t*) "\n", 1, 200);
                      cnt = 0;
                      // splitting the good NMEA sentence into the tokens by the comma delimiter
                      for (char *pV = strtok(nmeaSnt, ","); pV != NULL; pV = strtok(NULL, ",")) {
                          switch (cnt) {
                          case 1:
                              latRaw = strdup(pV);
                              break;
                          case 2:
                              hemNS = strdup(pV);
                              break;
                          case 3:
                              lonRaw = strdup(pV);
                              break;
                          case 4:
                              hemEW = strdup(pV);
                              break;
                          case 5:
                              utcRaw = strdup(pV);
                              break;
                          cnt++;
                      memcpy(latDg, &latRaw[0], 2);
                      latDg[2] = '\0';
                      memcpy(latMS, &latRaw[2], 7);
                      latMS[7] = '\0';
                      memcpy(lonDg, &lonRaw[0], 3);
                      lonDg[3] = '\0';
                      memcpy(lonMS, &lonRaw[3], 7);
                      lonMS[7] = '\0';
                      char strLonMS[7];
                      sprintf(strLonMS, "%s", lonMS);
                      memcpy(hH, &utcRaw[0], 2);
                      hH[2] = '\0';
                      memcpy(mM, &utcRaw[2], 2);
                      mM[2] = '\0';
                      memcpy(sS, &utcRaw[4], 2);
                      sS[2] = '\0';
                      strcpy(strUTC, hH);
                      strcat(strUTC, ":");
                      strcat(strUTC, mM);
                      strcat(strUTC, sS);
                      strUTC[8] = '\0';
                      HAL_UART_Transmit(&huart2, (uint8_t*) hemNS, 1, 200);
                      HAL_UART_Transmit(&huart2, (uint8_t*) " ", 1, 200);
                      HAL_UART_Transmit(&huart2, (uint8_t*) latDg, 2, 200);
                      HAL_UART_Transmit(&huart2, (uint8_t*) "\241", 1, 200);
                      HAL_UART_Transmit(&huart2, (uint8_t*) latMS, 7, 200);
                      HAL_UART_Transmit(&huart2, (uint8_t*) "\', ", 3, 200);
                      HAL_UART_Transmit(&huart2, (uint8_t*) hemEW, 1, 200);
                      HAL_UART_Transmit(&huart2, (uint8_t*) lonDg, 3, 200);
                      HAL_UART_Transmit(&huart2, (uint8_t*) strLonMS, strlen(strLonMS), 200);
                      HAL_UART_Transmit(&huart2, (uint8_t*) "\', UTC: ", 8, 200);
                      HAL_UART_Transmit(&huart2, (uint8_t*) strUTC, 8, 200);
          flag = 0;
      HAL_Delay(300);
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
  * @brief USART1 Initialization Function
  * [USER=120004]@Param[/USER] None
  * @retval None
  /* USER CODE BEGIN USART1_Init 0 */
  /* USER CODE END USART1_Init 0 */
  /* USER CODE BEGIN USART1_Init 1 */
  /* USER CODE END USART1_Init 1 */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 9600;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart1) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART1_Init 2 */
  /* USER CODE END USART1_Init 2 */
  * @brief USART2 Initialization Function
  * @retval None
  /* USER CODE BEGIN USART2_Init 0 */
  /* USER CODE END USART2_Init 0 */
  /* USER CODE BEGIN USART2_Init 1 */
  /* USER CODE END USART2_Init 1 */
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 9600;
  huart2.Init.WordLength = UART_WORDLENGTH_8B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_NONE;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART2_Init 2 */
  /* USER CODE END USART2_Init 2 */
  * Enable DMA controller clock
  /* DMA controller clock enable */
  __HAL_RCC_DMA2_CLK_ENABLE();
  /* DMA interrupt init */
  /* DMA2_Stream2_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(DMA2_Stream2_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(DMA2_Stream2_IRQn);
  * @brief GPIO Initialization Function
  * @retval None
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOA_CLK_ENABLE();
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * [USER=120004]@Param[/USER]  file: pointer to the source file name
  * [USER=120004]@Param[/USER]  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
E Microcontrollers 33
S Microcontrollers 0
