yep. just about does it for the burnt components. and yes, I know how to solder and take voltage readings![]()
High Res if u like
Is that it? Any other burned components.?
Do u have the know how on soldering and voltage measurements buddy.
I think I know how to isolate the PSU, but you better show me how, just to be sure.U can replace the output transistors with later, better ones u know.
Next u need to find two resistors of around 5W 18Ω to 22Ω will do.
Can U isolate the left right channels from the PSU ?
Or do u want me to show u how to do it ?
yep. the amp board is okay, besides that one burnt transistorHmm. Before tht tell me the status of the amp
everything is good besides the 3 burnt resistors and the one burnt transistorone ??
I see 3.!
my multimeter doesn't have a cap testerIf you have a DMM with cap. tester, I suggest to take out some electrolytic caps, and see if they are still OK.
The board seems to be old, 1970s, from the make of the resistors.
40 years are beyond useful service life for electrolytics.
I have seen one's from the late 1980s failing already, and causing malfunction, kind of the board worked for an hour, then became erractic, then stopped working altogether.
I would even consider to exchange all electrolytic caps.
But if you take out a few and they measure 100% OK, maybe not needed.
what transistors would you recommend.U can replace the output transistors with later, better ones u know.
So, what u need to do is find new components to replace the burned ones. They are quarter watt carbon type resistors. Very cheap.
Next take out the output transistors.
Discharge all the big capacitors after disconnecting power.
Put the DMM in diode check mode and check for shorted transistors in the circuit. No need to take em out. Make sure there are no shorted driver transistors.
While u are at it check all of them transistors and diodes for dead short.
If u find shorted ones, u need to replace them transistors or diodes. I bet u can figure out the replacement by googling.![]()
Replace any blown fuse with the correct type
If everything is A OK, then take a look at the shemaic power supply section.
I need u to isolate the PSU from the amp and test it.
Okay gotchaI'll have to check transistor data for a suitable replacement.
The 22 ohm resistors will be used to trouble shoot the amp biasing. It will help in protecting the components if a fault still exists in the amp.
U can isolate the amp by disconnecting the ± Supply line. Keep the ground connected.
U need to cut the positive and negative rails tht powers the amplifier.
can u locate the wires from the schematic?
Ok nO prob.lemmee get back to u later after work.
Great! I just so happen to have a couple of BD139 and BD140 transistors in my parts box.The data for 2SA706 returns useless hits and even though some say BD139/140, so let's see if it true
But I Manage to locate the exact data specs from my database.
2SA706 - Si-P , uni-L 40V, 1A, 7.9W, 120MHz.
The exact replacement I found was the BD256. The data shows the complementary no. too
The BD139 and BD140 are suitable replacement and is available.
See to it tht u replace Q705 too, as these two are complementary pairs and should be matched for lowest cross over distortion.
U need to isolate the positive and negative wires tht connects to the out put transistors. This way u are sure tht no heavy load is connected to the PSU during testing.
Make sure tht both channels are disconnected.
| Thread starter | Similar threads | Forum | Replies | Date |
| M | Home stereo receiver, no power | Technical Repair | 23 | |
| F | ESP32-S3 started outputting NMEA GPS location frames after EMC disturbance — what mode is this? | Microcontrollers | 4 |
