hi, i want to use stereo jack (male/female) as a power cable.
What side I should wire the positive/live wire on the stereo jack left or right? I know those are left and right stereo signal and the long pin is the neutral/ground but i want to use it as 12v power cable.
I have wired the female stereo jack the live wire on the right side and also on the stereo male jack and the project i am working on is working fine but i just want to be sure that i wired them correctly so if i am using some none of mine stereo male jack input power cable as is led strip etc that it will work and not short circuiting.,
Moderators note : removed double picture
