Stepping up the current
28,029
I am a bit puzzled as to what sort of system draws 117 amps constantly. That could be an electric racing cycle or a small car. Or possibly an electric airplane.
Can you provide a few details about the high powered project???
Admsher
Joined Sep 18, 2024
12
Something like that, it's a VTOL with high voltage tilt motors
28,029
OK, it is an aircraft. That changes things a lot!! Both size and weight matter much more on aircraft, and vibration can cause lots of problems. And the requirements become different because charging and using are in totally different environments. So a universal package is not the best choice. And none of the charging system needs to go along for flying. So that TI package is not what you need.
Good news, though, is that TI will probably be glad to help select the best choices for both use and charging.
Admsher
Joined Sep 18, 2024
12
This did have a mention about using it in a a vehicle so i thought it would work, but i think asking them is a better solution for this
