Steering wheel interferes the bridge amplifier
ilker06
Joined Jun 26, 2018
34
Hi masters,
I made a siren and a bridge amplifier for my car and the result is almost perfect except the above mentioned problem.
When the car is running but not moving, as soon as I start to turn the steering wheel a little buzzing sound comes from the horn speaker.
When I leave the steering wheel it stops. Probably electric assisted steering wheel system is the reason of the matter.
I put a 2200 uF between positive and negative terminal of the amplifier and siren. It reduced a little bit but did not remove the buzzing. I put a 1N4007 between positive and negative terminal, the result is the same.
I don't know do I have to use a coaxial screened cable form amplifier to horn speaker. Can audio output cable catch this kind of noises ?
What kind of filter do you advice to stop this buzzing ?
Thanks in advance.
ilker
Hymie
Joined Mar 30, 2018
1,347
Hi masters,
Thanks in advance.
ilker
I would recommend you try something as simple as the attached circuit, supplying power to your amp & siren.
Diode D1 must be rated for the load current, capacitor C1 could be your 2,200uF electrolytic with C2 being a 100nF capacitor.
Increasing the value of C1 will reduce the 12V line noise further.
38,522
If that doesn't work adequately, you can also try adding a small resistance in series with the diode, perhaps a few ohms, depending upon the current drawn by the siren.
