Steering of 4-wheel robot
beatsal
Joined Jan 21, 2018
425
I am trying to build a 4-wheel moving platform with differential steering on the rear wheels. Initially, the front 2 wheels were on the same axle, however it refused to steer, just go in a straight line. Then, I used a front swivel wheel, worked better but would not follow the same path from forward to reverse. Then used 2 front swivel wheels, same problem. The swivel wheels could turn 360 deg, not sure if this was the cause. Any thoughts or suggestions?
Ian0
Joined Aug 7, 2020
13,276
Four wheels in a diamond pattern. Single front and rear wheels on castors, and power the other two.
