How to resolve this problem so I could simulate AC sweep with no errors !In DC steady-state analysis PSpice treats all capacitors as a open circuit and inductors as a short circuit. And this is why the nodal voltage is floating.
Skipping does not help!Or skip DC point calculation.
Also, why the hell is this a poll?
There is no errors , but ""print parts"" shows that voltages and currents are zeroes!Add 1G resistor parallel with capacitors.
AC sweep analysis linear at 1 point in start&end 50 Khz!Are you preforming AC sweep analysis ??
Thanks for help!Change into Octave and 110 points per octave.
