starting current
96y
Joined May 8, 2019
38
When starting a 4 litre 6 cylinder gas engine..using math, how long will an 80 farad supercap array deliver
sufficient volts(above 12.4) before it falls below that??The caps would start at 13 v and deliver up to 250 amps..??
oz93666
Joined Sep 7, 2010
742
Energy stored in a cap is 1/2 x C x V x V
@ 13 V ................... = 1/2 x 80 x 13 x 13 = 6760 J
@ 12.4 ..................= 1/2 x 80 x 12.4 x 12.4 = 6150 J
You have to subtract one figure from the other to get 610 Joules .... this is the energy released when discharged from 13 to 12,4 ....
@ 250 Amps and 12.7 V energy is consumed at the rate of 250 x 12.7 = 3175 Joules per second
So the cap alone would only crank the engine for less than 0.2 secs !!!
In practice the battery is usually helping , and cranking still occurs down to about 10 V releasing more energy from the cap.
38,826
The cap voltage drop is ΔV= (i*t)/C so for a 0.6V drop the time is:
t = ΔV*C/i = 0.6V*80F/250A = 0.192 sec
(as oz93666 calculated above using energy).
If you allow it to drop to 10V, then the time would be:
3V*80F/250A = 0.96 sec.
oz93666
Joined Sep 7, 2010
742
That seems a lot simpler your way , crutschow ... I'm just trying to get my head around how you did it!
