Stage Line 500W amp repair, help please
Rookieme
Joined Jan 26, 2021
308
I am not sure if i have either of those resistors, i will have a rummage through my box of bits tomorrow and see what i can find
Rookieme
Joined Jan 26, 2021
308
T4 and T9 are the amplifiers ground line. (Marked 0vP) The outputs T5 and T10 seem reasonable.
If you look at the schematic you will notice that The missing components are marked "N.F." (Not fitted.) These are probably fitted in a higher power version of the amplifier.
For the right hand amplifier if you connect the negative of a 1.5 volts cell (AA or AAA) to the 0vP rail and the positive to In - R (The junction of R77 an R69) via a 1.8 or 2.2K resistor I would expect the output of the amplifier to read about -4.5 volts.
The same should happen if this is done to the corresponding points on the left hand channel. If the polaritu of the 1.5 volt cell is reversed the output should go to about +4.5 volts.
Les.
When you say connect the negative to 0vP, is that T4 and T9 ?
Rookieme
Joined Jan 26, 2021
308
Ok, replaced Q28 with the old good one, now it powers up with no fault LED,s at all, however F2 LED is on dimm but not blowing the resistor, think i am at the end of my knowlage now lol
Oh and this was down to a faulty fuseable resiater
LesJones
Joined Jan 8, 2017
4,509
The resistor is not really necessary, it is just to limit the current in case you connect to the wrong place. I suggest not using resistor much below 1K. If we call the value of the resistor that you use RX then the expected output voltage should be about - (12000 x 1.5)/(2000 + RX) (Notice the - sign at the start of the formula. It indicates that the output voltage will be the opposite polarity to the 1.5 volt cell) The 4.5 volts I quoted was based on a 2 K resistor and 1.8K and 2.2K are the nearest standard values.
0vP is just what they call the amplifier ground. (Which may not be connected to the mains safety ground.) This will also be connected to the outer of any coaxial input sockets such as phono or BNC.
Les.
34,966
Grounds can be confusing at times. On this unit there are numerous points that are at 0V.
T35 from transformer
T21, T26
0V
0VD - digital
0VA - analog
0VREF
Chassis
0VP(L) - T20 - power amp Left Channel
0VP(R) - T22 - power amp Right Channel
T4 - speaker Left Channel
T9 - speaker Right Channel
Eventually they all go back to 0V at T21.
You should confirm this by testing with an ohmmeter on the lowest range with power off.
Confirm that the Chassis shows 0-ohms to any or all of the above and you can use this as your 0V reference for voltage metering.
This should also show continuity with the EARTH pin on your AC power plug.
Rookieme
Joined Jan 26, 2021
308
T21, T26
0V
0VD - digital
0VA - analog
0VREF
Chassis
That is very helpfull, thank you
34,966
If you are getting close to 0V at the channel outputs T5 and T10 that is good. That is what we are hoping to get.
The next step would be to do a signal test. For this, you will connect a signal source to the inputs. Now is the time to find a PC audio amp, single channel will do. Also see if you can find a cheap speaker that you don't mind destroying.
You will also need a small electrolytic capacitor, 10-100μF will do (almost any voltage 16-50V).
Rookieme
Joined Jan 26, 2021
308
Les.
Rookieme
Joined Jan 26, 2021
308
Les.
I assume i will have to reinstall Q28 for this test ?
LesJones
Joined Jan 8, 2017
4,509
I had not realised that you did the previous tests with missing components. Are there any other missing components ? We need to know the ACTUAL schematic, not just the schematic as it should be.
Les.
Rookieme
Joined Jan 26, 2021
308
Les.
No everyting that should be fitted is now fitted
LesJones
Joined Jan 8, 2017
4,509
In my quick calculation of the expected outout voltage I had ignored the effect of R77. adding the effect of that the calculated reading should be 3.2 volts. The actual reading is close enough to that. Repeat the test with the cell reversed. If you get close to + 3.2 volts reading then all of that channel power amplifier is working to some extent. We won't know if it is fully working until we feed it into a dummy load and drive it fully. (Is the rated load impedance 4 ohms in none bridged mode ?)
LesJones
Joined Jan 8, 2017
4,509
I am surprised that there is a significant difference in the readings between the channels as the gain setting resistors (R67 and R79) are 1% tolerance. What voltage output did you get on the left hand channel when injecting a positive signal ?
Edit. I did not realise that you had swapped channels between posts #52 and #53. I thought you had just replaced the missing transistor.
Les.
Rookieme
Joined Jan 26, 2021
308
With the battery attached the o/p voltage seems to slowly climb on the left chanel, not sure if the right side did this
