Square waveform needs duty cycle adjustsment
relicmarks
Joined Oct 13, 2006
355
My function generator Square waveform output does not have a duty cycle adjustsment parameter
What kind of circuit/network can i hook up to it so i can adjust the 50% squarewaveform to any duty cycle % percentage from 0% to 99%??
What circuit can do this please?
My Triangle output does NOT have a "Symmetery" parameter how can i hook up a Function generator output triangle waveform and what circuit/network will adjust the positive and negative symmetery?
My Function generator does NOT have DC offset adjustsment parameter , What can i hook up to it so it can have a DC offset adjustsable?
I was thinking i can hook up a 9 volt battery with a 1Meg pot to variable the DC 9 volts from zero 0volts to 9 volts and put that on the function generator RED probe
Would this create a DC offset network for the function generator?
SgtWookie
Joined Jul 17, 2007
22,230
Did you build the function generator, or did you buy it already assembled?
It might be easier to start over than to start adding things on to it.
You're going to be rather hard-pressed to get nearly 0% or nearly 100% duty cycle from a signal generator at even moderate frequencies. That requires a great deal of bandwidth.
relicmarks
Joined Oct 13, 2006
355
its already built
I'm trying to build a circuit or network AFTER the function generator to make it had a duty cycle parameter
Block diagram::
Function generator output-- goes to a duty cycle circuit--- output
SgtWookie
Joined Jul 17, 2007
22,230
What Thingmaker3 said.
Look at 555 timer monostable circuits. You can get a pretty broad range of frequencies from them, from fractions of Hz to about 0.5MHz. Your minimum ON-time will be in the 1uS range, and at that speed the output waveform won't be terribly square.
