spikes problem of switching converters
Marc Sugrue
Joined Jan 19, 2018
222
I designed cascaded converters and I have switching spikes at the output c6. spikes and zoom on each spike is attached. how to eliminate it? I used snubber circuit
You could have a poor quality inductor with large leakage inductance or poor PCB layout such as thin tracks or wires in switching paths giving large parasitic inductance. Pehaps consider sharing your PCB layout.
28,424
What you have is two cascaded switching mode power supplies. And the circuits appear to be the same as when they were in that other thread. The operation of a switching power supply is actually quite complex because of the quite lare currents being switched very rapidly. Thus every interconnection that has current flowing is subject to the influence of the actual and effective impedance of that connection. That means that every current loop needs to be recognized and understood so tghat the PCB layout will avoid causing problems like spikes and noise.
Several semiconductor producers have excellent design resources available and I suggest visiting them and learning what they can provide.
mihiramehta
Joined Jul 21, 2020
1. Have you tried adding ferrite on the output. That may provide some help.
2. Did you guess the RC values for the snubber or selected them measuring the circuits parasitic capacitance and inductance?
Papabravo
Joined Feb 24, 2006
22,113
Doing something about them after the fact is unlikely to produce satisfactory results. You need to eliminate them by design from the get go. I have not seen a single engineer get this right the first time - welcome to the club.
28,424
Read what Bob Pease and JIm Williams had to say about switching mode power supply design. And if those two masters told us that the designs are complex and tricky I do believe them. Aside from the actual circuit, the PCB layout is also tricky.
Papabravo iscertainly correct.
