Spike suppressor
Andye
Joined Mar 8, 2022
Hi guys I am an electrician and was called out to an electronic Din rail digital timeclock that was flashing saying no mains but the supply was ok so I suspect it got a spike or surge if that the right words to use during the night.
So my question is what would be the best cost effective product to protect this type of thing
Many thanks in advance for your help
Andy
MaxHeadRoom
Joined Jul 18, 2013
30,776
Does the timeclock do this on power removal and when power re-applied.?
If so, just wondering if it was a brown-out during the night.?
Andye
Joined Mar 8, 2022
The timeclock when power removed flashes a plug sign to say no power. Only problem was there was power. I replaced it then took it home and connected a lead to it so same situation plug sign flashing when power is on.
Brown-out ?
MaxHeadRoom
Joined Jul 18, 2013
30,776
Brown-out is less drastic than a power outage, just a very low dip in voltage.
So it does flash the same thing when power removed, how can you be sure you did not experience a short power loss during the night?
Andye
Joined Mar 8, 2022
Well yes you could be right hence why I was asking if there was a spike or surge arrestor.
Also the term Brownout is this a US forum as I am in the UK
MaxHeadRoom
Joined Jul 18, 2013
30,776
I am in N.A. but did my training in the UK, I can't remember if we used it there also?
A surge arrestor will be no good, if it is a brown-out or drop or loss of power causing it.
