Hi all
I am trying to use spi protocoll between 2 pics. 16F18346 is master mode and 16F1829 is slave mode. Master sends 1 waits 5sec and sends a 0. The slave operates an led acording the on off commands. Also the SS pin on slave side is active.Simple looks but?? I enclose the codes if anyone can see something wrong because project is not working at all. Thanks.
Master SPI:
/* Files to Include */
#if defined(__XC)
#include <xc.h> /* XC8 General Include File */
#elif defined(HI_TECH_C)
#include <htc.h> /* HiTech General Include File */
#endif
#include <stdint.h> /* For uint8_t definition */
#include <stdbool.h> /* For true/false definition */
#include "system.h" /* System funct/params, like osc/peripheral config */
#include "user.h" /* User funct/params, such as InitApp */
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
/* User Global Variable Declaration */
#define _XTAL_FREQ 4000000
/* i.e. uint8_t <variable_name>; */
/* Main Program */
void SPI_Master_Init();
void SPI_Write(unsigned char x);
unsigned char SPI_Read();
unsigned char DataRdySPI( void );
void main(void)
/* Configure the oscillator for the device */
ConfigureOscillator();
// NOSC HFINTOSC; NDIV 4;
OSCCON1 = 0x62;
// CSWHOLD may proceed; SOSCPWR Low power; SOSCBE crystal oscillator;
OSCCON3 = 0x00;
// LFOEN disabled; ADOEN disabled; SOSCEN disabled; EXTOEN disabled; HFOEN disabled;
OSCEN = 0x00;
// HFFRQ 4_MHz;
OSCFRQ = 0x03;
// HFTUN 0;
OSCTUNE = 0x00;
/* Initialise I/O and Peripherals for application */
InitApp();
SPI_Master_Init();
LATCbits.LATC0 = 1; // Select slave high
while(1)
LATCbits.LATC0 = 0;
__delay_ms(2);
SPI_Write(0x01);
__delay_ms(2);
LATCbits.LATC0 = 1;
__delay_ms(5000);
LATCbits.LATC0 = 0;
__delay_ms(2);
SPI_Write(0x00);
__delay_ms(2);
LATCbits.LATC0 = 1;
__delay_ms(5000);
// Set SPI Mode To Master + Set SCK Rate To FOSC/4
SSP1CON1bits.SSPM = 0x00;
// Enable The Synchronous Serial Port
SSP1CON1bits.SSPEN = 1;
// Configure The Clock Polarity & Phase
SSP1STATbits.CKE = 1;
SSP1CON1bits.CKP = 0;
// Configure The Sampling Time (Let's make it at middle)
SSP1STATbits.SMP = 0;
// Set BaudRate
SSP1ADD = 0x01;
// Configure The IO Pins For SPI Master Mode
TRISBbits.TRISB4 = 1; // SDI -> Input
TRISBbits.TRISB6 = 0; // SCK -> Output
TRISCbits.TRISC0 = 0; // SS -> Output
TRISCbits.TRISC6 = 0; // SDO -> Output
ANSELB = 0x00;
ANSELC = 0x00;
SSP1CLKPPS = 0x0E; // RB6->MSSP1:SCK1;
RB6PPS = 0x18; // RB6->MSSP1:SCK1;
RC6PPS = 0x19; // RC6->MSSP1:SDO1;
SSP1DATPPS = 0x0C; // RB4->MSSP1:SDI1;
PIE1bits.SSP1IE = 1;
INTCONbits.PEIE = 1;
INTCONbits.GIE = 1;
unsigned char data_flush;
SSP1BUF=x; /* Copy data in SSBUF to transmit */
while(!PIR1bits.SSP1IF); /* Wait for complete 1 byte transmission */
PIR1bits.SSP1IF=0; /* Clear SSPIF flag */
data_flush=SSP1BUF; /* Flush the data */
SSP1BUF=0xff; /* Copy flush byte in SSBUF */
PIR1bits.SSP1IF=0;
return(SSP1BUF); /* Return received byte */
Slave SPI:
#if defined(__XC)
#endif
char incoming = 0;
/* Main Program */
void SPI_Slave_Init();
void main(void)
// SCS INTOSC; SPLLEN disabled; IRCF 4MHz_HF;
OSCCON = 0x6A;
// TUN 0;
OSCTUNE = 0x00;
// SBOREN disabled;
BORCON = 0x00;
InitApp();
SPI_Slave_Init();
LATBbits.LATB7 = 0; //LED = off
while(1)
incoming = SPI_Read();
switch(incoming){
case 1: LATBbits.LATB7 = 1; //LED on
break;
case 0: LATBbits.LATB7 = 0; //LED off
break;
// Set SPI Mode To Master + Set SCK Rate To Fosc/4
SSP1CON1bits.SSPM = 0b0100;
SSP1ADD = 0x00;
TRISCbits.TRISC6 = 1; // SS -> Input
TRISCbits.TRISC7 = 0; // SDO -> Output
TRISBbits.TRISB6 = 1; // SCK -> Output
TRISBbits.TRISB7 = 0; // LED -> Output
ANSELB = 0x00;
ANSELC = 0x00;
APFCONx registers
APFCON0 = 0x00;
APFCON1 = 0x00;
PEIE = 1;
GIE = 1;
SSP2BUF = x; /* Copy data in SSBUF to transmit */
while(!PIR4bits.SSP2IF); /* Wait for complete 1 byte transmission */
PIR4bits.SSP2IF = 0; /* Clear SSPIF flag */
data_flush = SSP2BUF; /* Flush the data */
SSP2BUF=0xff; /* Copy flush byte in SSBUF */
return(SSP2BUF); /* Return received byte */
