Spark gaps in series
38,698
I removed my other post since I thought it was wrong, but upon further reflection, I think I do agree with SamR, that is the sum of the two voltages.
Capernicus
Joined Jun 24, 2022
87
Thankyou, that is amazing. I cant believe u knew that.
So u can make it so? But if not it does count as 180!!
I'm making a marx generator, and I dont see how you can go through all those spark gaps in series, and still make it through them all, wouldn't it add up and make it not be able to make it unless the power supply equalled the spark gap distance, and travel through it anyway? (Because there is one spark gap per capacitor, so if one couldnt make it, none of them could)
Sorry if thats a bit confusing, but I do have a trial circuit to try and do it with 1 spark gap by itself, ill try it out.
SamR
Joined Mar 19, 2019
5,528
The question is, Can the single gas discharge tube rated for 90V survive the initial inrush of 180+V? That I am not sure about... If you look at it as a resistor then yes.
Capernicus
Joined Jun 24, 2022
87
Arent they invincible to any amount of volts? cause arent they effectively a blown capacitor when they are passing the current through - so they dont even blow up.
Does seem to be able to make it through the spark gaps, if they add effect in series.
It jumps each spark gap sequentially up the ladder and shorts the gap connection to place the charged capacitors in series, upping the total voltage across the gaps.
SamR
Joined Mar 19, 2019
5,528
The ones I have are for lightning suppression on coax feed lines to my antennas. So, when they get zapped at extremely high voltage, they are the sacrificial element that has to be replaced. Much cheaper than the radios. Not quite the same as what you have but I would check the specifications for the tubes.
Capernicus
Joined Jun 24, 2022
87
How do they blow up? Does the gas expand inside them?
SamR
Joined Mar 19, 2019
5,528
Nope, usually melts the solder on the end caps or erodes/vaporizes the "pin" they are pressed against and causes an even greater spark gap to ground. The problem I have is they need a regular inspection because you cannot tell if they are working or damaged. They have never suffered a direct hit but even far misses can generate quite a bit of induced voltage. Years ago I came home and it was raining a gulley washer. So I jumped out of the car and put my briefcase over my head to keep the rain off my glasses and ran for the house. Lightning struck some distance away and the aluminum frame of the briefcase was induced with enough voltage to arc over to my hand giving me a bit of jolt as you get from static electricity and the doorknob. Not enough to really hurt but enough to get a few choice words out of me.
Capernicus
Joined Jun 24, 2022
87
Heres a picture of my new to attempt single spark gap marx generator
The diodes will short the current to the capacitors, the "cross diagonal dischargers" have a 1 ohm resistance, and it charges up, and it discharges down, back through the resistors.
I dont know if itll work, it seems to be a miracle if anything does. :p
Capernicus
Joined Jun 24, 2022
87
Were you being a sinner that day? I have to watch out for bird shit every day myself.
My gas discharge tubes glow when the electricity is going through them, they are quite flashy, have you got the same effect on yours?
DrBearEE
Joined Feb 3, 2020
9
Spark gaps are very high resistance until the voltage reaches the breakdown rating, then they are a short circuit until the arc clears. Before they fire, there is no way to determine the voltage that each one sees.
So if you want to put two spark gaps in series, you will need to add two series resistors (of very high value) across the spark gaps to make sure they each see half the total voltage.
If you don't do this, the effective breakdown voltage may be just a bit higher than the rating of one of the spark gaps, and it will depend on parasitic effects that are likely not stable, like surrounding humidity.
These resistors will have to be rated for the high voltage across them, and the circuit has to be constructed so that the resistor leads don't form another unintentional spark gap.
This is the same idea as the bleeder resistor stack you will see across the high voltage rectifier stack of a CRT or a tube plate supply. In that case the resistors make sure that each rectifier "shares" the reverse voltage, so that a stack of several rectifiers has a breakdown voltage that is the sum of the individual breakdown ratings. This is the same idea.
