Spare Alternator??
shortbus
Joined Sep 30, 2009
10,049
Never saw them done quite like that. Most of them take the rotor winding's out and replace them with ring permanent magnets. They first were done with speaker magnets until someone started making Neo type rings in the correct size. They also use those magnets when making wind generators from car alternators.
Externet
Joined Nov 29, 2005
2,676
If wired as wye instead of delta, could a higher battery voltage be used -respecting the inverter limits- ? What about the winding limitations ? Wye twice the delta ?
That would translate in smaller current drain with the same horsepower, right ?
What is the effect of raising the field voltage winding here ? More torque, or more speed, or... ?
shortbus
Joined Sep 30, 2009
10,049
He is using 12v on the rotor, in an alternator setting, it vary rarely hits 12v due to the regulator.
Max.
If he is using the full 12V on the rotor he is using more than twice what a normal alternator uses. They are usually in the ~5V range on the rotor winding's.
MaxHeadRoom
Joined Jul 18, 2013
30,808
Yes, the modern regulators now are usually PWM into the field so the mean current will vary with the 12v PWM.
The first electronic ones were an exact electronic representation of the mechanical version but caused radio interference, hence the conversion to PWM.
Max.
wayneh
Joined Sep 9, 2010
18,162
shortbus
Joined Sep 30, 2009
10,049
Here's what a genuine 5HP electric motor looks like.
Think your doing one of those apples to oranges things using that as an example.:) In effect they are making the alternator into a BLDC motor, that is more efficient than an AC motor. That is why more and more appliance and power tool motors are now BLDC, more power in a smaller package.
wayneh
Joined Sep 9, 2010
18,162
Maybe so. I remain skeptical until I see some data. I can’t imagine pumping 3000 watts into that thing without something going poof.
