***Sourcing Power IGBT without Parallel Diode***
artmaster547
Joined Jan 6, 2016
409
Hi all I was wondering if anyone could suggest any manufacturers of power IGBT's that do not have parallel diodes, I am struggling to find any they need to withstand a max of 600V and 450A.
Art
kubeek
Joined Sep 20, 2005
5,796
Why do you need such feature?
Try searching for reverse blocking igbt, but I think you will be dissapointed.
ian field
Joined Oct 27, 2012
6,536
Art
The body diode is certainly inherent in a MOSFET, I think it may also be in the IGBT.
The only option might be a blocking rectifier in series with the load.
ian field
Joined Oct 27, 2012
6,536
I'd steer clear of a reference source that thinks that's the IGBT equivalent circuit.
The IGBT is essentially a MOSFET with an emitter follower hung from its drain. The B/E junction is in series with the MOSFET body diode and in the same direction, so a blocking rectifier in series with the load would be required by the TS.
kubeek
Joined Sep 20, 2005
5,796
Yes, but the fact that they don´t have the diode doesn´t mean they can withstand reverse voltage. Again, why do you need such a feature?
I found this article https://www.powersystemsdesign.com/...-modules-a-novel-possibility-with-rb-igbts/95
A conventional IGBT has forward and reverse blocking capability. So theoretically, we can use the IGBT to block reverse voltages equivalent to the IGBT forward voltage rating. However, practically, this is not true. Under reverse bias, there is a leakage current, the dependence of this current on reverse voltage is exponential.
artmaster547
Joined Jan 6, 2016
409
R!f@@
Joined Apr 2, 2009
10,014
I just googled "450A IGBT without diode"
Still I am sorry for wasting your time.
The diode is needed only if the application requires for it, If it don't, it doesn't hurt whether you have it or not.
artmaster547
Joined Jan 6, 2016
409
yep thank you anyway appreciate you taking time to check this post :)
