Hi all, I am looking for gate drivers for the following IGBT, I will be using four in parallel but want to use the same driver for all four (I am using four to meet the current and voltage requirements I had in mind: max 900V and max 500A, paralleling them up to meet the current requirement). The following is the datasheet for the IGBT I had in mind, if anyone could suggest a good driver. I will be using them as a static switch, so there is no set frequency it will be switched infrequently only ever so often. https://www.microsemi.com/document-portal/doc_view/5738-apt150gn120j-b-pdf
Thanks Arthur
Thanks Arthur
