Sound system design
mcgyvr
Joined Oct 15, 2009
5,394
What are the components that are require to design a sound system that use wireless transmitter
A capable brain is the component required to design a sound system using a wireless transmitter..
It is also the only component required to design anything..
But I think I read too much into your sentence ;)
mcgyvr
Joined Oct 15, 2009
5,394
What do you mean? By "capable brain"
The actual "design" of the sound system is done in ones brain on paper or in a computer system but again used and programmed via a brain (user)..
So the components required to design are a brain capable of doing the work..
As you needed to ask the question, your brain is not capable (currently) of designing such a system..
Through learning you may make your brain capable though..
The components of a sound system may be some mentioned above but without specifics of what this sound system entails we cannot answer your question..
Its too open/generic to properly answer with anything more than guesses and assumptions..
I could also say that a pencil may be a component required to design a sound system.. Or a computer.. Or paper.. Or a calculator..
