Sound Detector
ECErich
Joined Feb 4, 2015
5
Hi Everyone,
I was trying to build a circuit, i just want to find out how to start my design. Basically the circuit works if the presence of the sound is within the area. Can you help me where to start?
Thanks,
GopherT
Joined Nov 23, 2012
8,009
get a microphone (electret is easiest)
Connect to an op Amp.
OPTION 1
Connect to an LM3915.
Connect 3915 to 10 LEDs to show sound level (see data sheet for range of each LED)
Option 2
Connect Op Amp ampliefier to volt meter and read sound level
OPTION 3
Connect OP Amp as comparator
Connect Op amp output to simple LED (Sound above threshold yes/no)
Option 4...
You need to tell us what "presence of sound" means and what kind of output accuracy you need. What kind of output you need (light, bar graph, number, buzzer, actuator, motor, ...)
ECErich
Joined Feb 4, 2015
5
Thank you GopherT for you reply. The "presence sound" is the sound of the Cane Toad(Frog). I try to simulate it using Audicity Software to get the response between time vs amplitude and freq vs db. I want to determine the operating frequency and design a circuit that can only detects the Cane Toad sound.The output that I'm planning to be use is motor.
18,104
And define what you mean by "sound", in terms of frequency. 12kHz is sound to my kids, but not me.
Oops, cross post.
ECErich
Joined Feb 4, 2015
5
Thanks to you all,
I want to create a project that can only detect the sound of a frog that can output to a servo motor. If the sound detected is not a frog voice the circuit does not operate.
GopherT
Joined Nov 23, 2012
8,009
Thanks to you all,
If that is the case, you need to tell us what is unique about the sound of the frog that be isolated from other sounds.
Reloadron
Joined Jan 15, 2015
7,889
Well not so sure as to the frog, I haven't spoken to any lately. However, when I was talking with frogs each did have a unique voice by species of frog.
If you want something to respond to a narrow band of frequencies you might be able to do it with a notch filter of sorts. Just a matter of knowing the frequency range you want and filtering out frequencies above and below. The trick is knowing the frequency range you want.
Ron
Bernard
Joined Aug 7, 2008
5,784
Does frog croak in a repeating pattern, say 3 croaks in 5 sec? Each croak lasts about 1 sec? Do we need to know direction of sound?
GopherT
Joined Nov 23, 2012
8,009
I think a filter will work better when coupled with a Microcontroller. Most frogs have a quickly repeating tone. Like a 120 Hz that flutters on/off at about 4 to 8 Hz. Get a sound file and look at it as an oscilloscope view and see what unique identifying features you can find.
ECErich
Joined Feb 4, 2015
5
I uploaded some spectrum graph. Can you tell me what type of approach and design that I need to do.
Sorry everyone if i cannot explain it more clearly and specific. That's why I'm here to seek help!. thank you all
Bernard
Joined Aug 7, 2008
5,784
A good start. Are there any other sounds in the neighborhood that are close to the frog? Does the pattern for both repeat in any recogniasible pattern?
Magician
Joined Aug 18, 2014
13
No , you can't use frequency - magnitude plot only. Timing is very important as well. What you need is frequency-time-magnitude, they called it's waterfall spectrogram.
Alec_t
Joined Sep 17, 2013
15,118
The cane toad call waveform looks like this :-
Each major burst shown consists of a series of many minor bursts repeated at ~ 16Hz. Here's a series of just three minor bursts :-
Each minor burst consists of an amplitude modulated tone of ~605Hz (though the tone frequency varies slightly within a minor burst). The modulation envelope has strong periodic components at ~77Hz and 105Hz.
A starting point in identifying a toad call might therefore be to build an amp plus a narrow-band-pass filter centred on 605Hz. But variations in call between gender/species/individuals would probably mean more complex signal processing would be required.
An MP3 of the toad call is downloadable from here.
