Sony TA-FE230 Amplifier 120W
LesJones
Joined Jan 8, 2017
4,522
Can you measure the following voltages.
C306 +
C306 -
C356 +
C356 -
Both sides of R305
Both sides of R306
Both sides of R355
Both sides of R356
Both sides of R307
Edit Also
Both sides of C353
Both sides of C303
Both sides of R353
Both sides of R303
Les.
spike1947
Joined Feb 4, 2016
537
Ok will do.
Tks
Spike
C306 + = 0v
C306 - = 43v
C356 + = 32.3v
C356 - = 39.1v
Both sides of R305 = 42v and 39v
Both sides of R306 = 41.8v and 44.7v
Both sides of R355 = 39.2v and 44.7v
Both sides of R356 = 44.7 and 44.8v
Both sides of R307 = 44.9v and 45.8v
Edit Also
Both sides of C353 = 26.4v and 26.3v
Both sides of C303 = 26.2v and 26.4v
Both sides of R353 = 26.3v and 26.4v
Both sides of R303 = 26.3v and 26.4v
Cheers
Spike
LesJones
Joined Jan 8, 2017
4,522
The readings from post #103 look reasonable but the offset on the top half (Right channeL ) have changed polarity since the readings from post #63.
Can you measure the voltage on both ends of R320.
Can you then remove power to the amplifier and give the capacitors time to discharge then measure the resistance between the ends of R320. Then measure the resistance between IC301 pin 5 and each end of R320.
Les.
spike1947
Joined Feb 4, 2016
537
Les.
Ok
Will do
Tk
Spike
spike1947
Joined Feb 4, 2016
537
Les.
Can you measure the voltage on both ends of R320 = 0v and 10mv.
Can you then remove power to the amplifier and give the capacitors time to discharge then measure the resistance between the ends of R320 = 2.3π
Then measure the resistance between IC301 pin 5 and each end of R320 = 2.3π and 0π
Cheers
Spike
LesJones
Joined Jan 8, 2017
4,522
Spike, Can you do the following tests.
Remove C356 and test it's leakage current with about 25 - 30 volts applied. (Make sure you have the polarity correct.) Also use a current limiting resistor to avoid the risk of damaging the meter that you use to measure the current. Measure the actual resistance of R355 and R356. You will have to disconnect one end of each resistor to get a correct reading.
This is the reason for the test. These 2 resistors are in series and have the same value so the voltage across each resistor should be the same. The only thing connected to the junction of these resistors is C356 and no DC current should pass through this.
Les.
spike1947
Joined Feb 4, 2016
537
Les.
Hi Les
Ok will do.
Tks
Spike
spike1947
Joined Feb 4, 2016
537
Les.
Charged @ 27v, current = 1.5mA
Measure the actual resistance of R355: = 3.28 kΩ and R356: = 3.28KΩ.
cheers and tks
Spike
LesJones
Joined Jan 8, 2017
4,522
So the resistors are OK but the capacitor needs replacing. If you use one that you have had in stock for a long time or salvaged from some other device then check it's leakage first.
Les.
spike1947
Joined Feb 4, 2016
537
Les.
Hi Les
What sort of current reading should a good Cap give ?.
cheers
Spike
LesJones
Joined Jan 8, 2017
4,522
I don't know if there is a specification for leakage current but I tested 330 uf 50 volt one and it's leakage was about 10 uA. This was not a new one it is one I removed from something else.
This may not be related to the fault we are trying to fix.
Les.
spike1947
Joined Feb 4, 2016
537
Les.
Hi
Only asked because I have 3 more of the same 47uf 25v, and they all seem to test the same and all hold a charge quite well, including the one I have taken out !.
cheers
Spike
