Sony TA-FE230 Amplifier 120W
spike1947
Joined Feb 4, 2016
537
Hi
I have a Sony DVP-SR760 Amplifier and when I connected it to my Turntable (with the volume on zero) then I just had to move the volume control nob slightly and the volume was just about right, I just thought it strange that I only had to move the volume such a small amount, anyway that was fine, the next time I switched the Amp on there was loud craking coming out of the speakers, that was with the volume at zero, they were very loud, I switched to Aux, then CD, then Phono, still loud cracking, then there was nothing coming out of the Amp., checked speakers and they are showing 6hms, so they seem not to of blown !
So the question is how do I test a Amps audio output ?.
Attached Service Manual.
cheers
Spike
Audioguru again
Joined Oct 21, 2019
6,826
The volume control on the amplifier needs to be replaced. It should be marked "A" for audio logarithmic ratio.
The common cause is that since the lowest loudness end of the resistive track has a grounded terminal riveted or simply squeezed on, it has become loose from being used many times. But you might be lucky and see that the ground terminal has a poor solder joint.
spike1947
Joined Feb 4, 2016
537
Thanks for that
28,231
Before replacing the volume control I suggest using some control cleaner, which usually is available in spray cans. Do the cleaning with the amplifier off and disconnected from the maims power. After spraying rotate the control back and forth over the whole rotation a few times.
If control cleaner is not available try denatured alcohol, which is sometimes successful.
Control cleaner is a great diagnostic tool on many occasions. The fix may not last, but it can verify that a control or a switch is noisy.
spike1947
Joined Feb 4, 2016
537
Thanks for that
spike1947
Joined Feb 4, 2016
537
Hi again
Having a problem finding the correct "Carbon Variable Resistor" if needed , Sony Part number: ( RV202 1-241-408-11 RES, VAR, CARBON 100K/100K (VOLUME).
as per pic attached.
Spike
spike1947
Joined Feb 4, 2016
537
Hi
Thanks for that, am going to do that now, will come back to you what the results will be !. cheers
LesJones
Joined Jan 8, 2017
4,543
Do you have the same problem with different audio sources when the turntable is NOT connected ? (Tuner, tape, aux.) Is the problem the same on both left and right channels ?
Les.
spike1947
Joined Feb 4, 2016
537
Les.
Hi
Thanks for your reply, have tried it using one speaker on each channel L & R it plays fine on both channels for about 1 min, then it cuts out , there is a relay on the board for the speaker output, that clicks out after about 1 minute !, whether anything is connected or not !.
cheers
LesJones
Joined Jan 8, 2017
4,543
It sounds like the protection circuitry is coming into play and disconnecting the speakers. With no speakers connected measure the DC voltage on pin 12 of IC301 with respect to the negative speaker terminal from the time you switch on until after the relay clicks on. Repeat this test but monitor the voltage on pin 15 of IC301. Report the results.
Les.
LesJones
Joined Jan 8, 2017
4,543
I should have also asked if the relay clicking fault still occurs with BOTH speakers connected and with NO speakers connected.
Les.
spike1947
Joined Feb 4, 2016
537
Les.
Hi
Thanks for your reply, I think I have knackered it, shorted it between 2 pins or a wire joint next to it, very difficult to get a probe on the pins of 301, now the relay does not operate, looking for a fuse on the transformed side can't find one, only fuse I can see is the mains in !.
Spike
spike1947
Joined Feb 4, 2016
537
Les.
Yes, whether anything or nothing is connected it will trip out after a couple of mins .
LesJones
Joined Jan 8, 2017
4,543
It may have been easier to access pin 12 at R364 or R368. The pins either side of pin 12 are the main + and - 49 volt rails so there is a good chance you have destroyed IC301. Are those two voltages present at connector CN951 on the same board as IC301 ?
Les.
spike1947
Joined Feb 4, 2016
537
Les.
Hi
Sorry for late reply, got 2 nippers to look after !, I can't see CN951 on the main board, can see CN952 !.
Spike
