What about R2? while finding equivalent resistance you need to consider R2 also.I mean you are considering only load resistance. That's why you are caluclating 100/50=2 Amps.Am I right?Ohm's Law?
I = V/R?
Regards,
Nandu.
R2 is in parallel with 50 Ohm. The nature of resistors in parallel is that same voltage appears across the resistors in parallel. So there is 100 volts across R2 and there is 100 volts across 50 Ohm. Since we are interested in power at 50 Ohm resistor, we use formula for power: P=VI. But! This same formula can be expressed in a couple of ways: P=VI=VV/R or P=VI=IIR. Since for 50 Ohm resistor we know V and we know R, we use formula P=VI=VV/R=100*100/50=200 Watts.What about R2? while finding equivalent resistance you need to consider R2 also.I mean you are considering only load resistance. That's why you are caluclating 100/50=2 Amps.Am I right?
Not quite - the resistance range was limited in the interview question from zero to 100.With R1 equal to zero, R2 can be anything from 1e-99 ohms to 1e99 ohms. It just doesn't matter.
True. I was speaking in general terms as the OP was worried too much about R2's resistance. R2 was the distractor in that question and not part of the stem ... the maximum power consumed by the load.Not quite - the resistance range was limited in the interview question from zero to 100.
Your problem stated that the two resistors can be any value from 0 to 100 ohms. You had to choose the values that would produce the maximum power in the 50 ohm load.What about R2? while finding equivalent resistance you need to consider R2 also.I mean you are considering only load resistance. That's why you are calculating 100/50=2 Amps. Am I right?
And it still does not matter.Not quite - the resistance range was limited in the interview question from zero to 100.
Thanks JoeJester for helping me. I completely understood your explanation. Could you please tell me what is your choice in choosing value of R2 (0<=R2<=100) according to the given circuit ?Your problem stated that the two resistors can be any value from 0 to 100 ohms. You had to choose the values that would produce the maximum power in the 50 ohm load.
R2, in parallel with the load has NO EFFECT on the power in the load. You can demonstrate that by applying a voltage across the parallel combination of R2 and the load and calculating the power. You can start with R2 being 1e-99 ohms and end with R2 being 1e2 ohms. You can increment R2 by a factor of 1o, until you either realize the power doesn't change or you reach 1e2.
The question did not ask anything about the total power. The question did not ask about total resistance. The question asked about the maximum power in the load. The word efficiency does not appear in your problem statement.
The question was designed by your potential employer as one that can be answered quickly, where you chose the proper value of R1 to deliver the maximum voltage across the parallel combination of R2 and the Load, producing the maximum power in the load.
My choice is whatever satisfies the requirement.Could you please tell me what is your choice in choosing value of R2 (0<=R2<=100) according to the given circuit ?
Don't matter because resistors in parallel have the same voltage across them. If R2 is 0, it has 100 volts across it. If R2 is 100, it has 100 volts across it. This is the nature of resistors in parallel. Why waste your life on useless crap.Could you please tell me what is your choice in choosing value of R2 (0<=R2<=100) according to the given circuit ?
But at interview you should also point out to the interviewer that there are multiple answers.It doesn't matter if there are multiple acceptable answers, you only need to provide one.
Where are you getting that claim from? Look at Post #1 and you will see that a value of 0 Ω is explicitly allowed for either resistor.R1 and R2 cannot be assumed zero for maximum power transfer to the load, in calculations, as it was stated (R1 and R2 are both greater than zero ohms).
You are wasting your breath -- I've been trying to get him to do that since Post #5 and he clearly has no desire to even attempt it so that we can discuss it.OP.
Reread and study up on,the algebraic (not actual voltage values) but the equation of load voltage value with respect to the supply voltage, in terms of max. power transfer.
Vload with respect to VDC.
When you understand the relationship of Vload to VDC, then solving for R1 and R2 will logically make sense, as you can then use basic (ohms and kirchoffs) theorems to solve it.
In fact you can write up the whole equation without any voltage or current values, to solve for any given load or supply voltage, its best to understand the equation for it, then actual values asked for at that moment.
