Unlike an ordinary signal or power diode, It is the nature of the behaviour of a zener diode that its zener voltage is the voltage at which it begins to conduct when it is reverse biased.Originally posted by celect@Jun 10 2005, 07:05 PM
I'm confused if this zener diode is connected to anode to a neg voltage source means it reversed bais does that mean its open
and i have 0-0.7 = -0.7V and V e
[post=8390]Quoted post[/post]
The zener diode is serving to provide a constant voltage that is applied to the base of the transistor. By using the zener in this way the voltage across the emitter resistor is held constant even if there are small variation in the -20V supply voltage. With a constant voltage across the emitter resistor then the emitter current is held constant and if the emitter current is held constant then the collector current is constant. Therefore the transistor acts as a constant current source.
hgmjr
