I was just going out to find my S-100 wire wrapped computer but you got there first.8080 graphics controller board.
As far as I know the ARM controller is latest microcontroller. I have read previous discussions. Architecture of ARM is much more difficult than the 8051& PIC microcontroller.The PIC is a much older device that you might think -
You'll find the ARM Cortex M0 looks very much, from a programming point of view, like an Atmel AT device. The RISC design means that the architecture is simple. The extra complexity comes from better peripherals, and lots of ways of shutting various bits of it down to save power.As far as I know the ARM controller is latest microcontroller. I have read previous discussions. Architecture of ARM is much more difficult than the 8051& PIC microcontroller.
Is ARM micro being used more than the PIC micro in projects now a days?
Pretty on the front but the backside is a little messy.I was just going out to find my S-100 wire wrapped computer but you got there first.
I have a 6805 development board wrapped up. Those were the days, glad we are not here now.
They even had mask programmable ROMs in those days.The PIC is a much older device that you might think - it started life as a support chip for a General Instruments processor back in 1976 - it stands for "peripheral interface controller" - and was originally fabricated in NMOS.
I remember when they said that pcbs were a thing of the past an wire-wrapping was the proper modern way to connect things up.Pretty on the front but the backside is a little messy.
https://forum.allaboutcircuits.com/threads/wire-wrap-intro.156341/post-1350183
I worked on the military's Harris mini-supercomputers in the 80's as a forward deployed (Subic Navy Base) equipment engineer for the Navy. The backplanes for the machines AN/UYK-62(v) were all wire-wrap with wire jumpers for board configuration and interrupts. I had a system where one of the ships local techs tried to fix a 50A 5V power supply problem and fried the backplane. What a field service nightmare.I remember when they said that pcbs were a thing of the past an wire-wrapping was the proper modern way to connect things up.
Same here, 6502 for Commodore along with BASIC. Accounting programs for a Construction Company. Back when I was a teenager. But I did have an assembler so I was not restricted to entering it all in hexadecimal.Writing 6502 code for a Commodore PET, assembling it by hand and entering it as hexadecimal (back in 1980). I was astonished how fast it ran compared to a high-level language (which, at that time, was BASIC)
Ah, wirewrapping... was a big thing once and preferred to making a PCB (even when we had PCB fabrication in house!). My Z80 and later an 8086-based home computers were all wirewrapped on double-height 160 x 223mm Eurocards and a wirewrapped backplane with those horrible 3-row DIN connectors in a 6U case in a 19" rack, which at one time, before I got married, had pride of place in my bedroom. It was a good thing they were used on so many MOD projects they were all issued FOC from the stores!Pretty on the front but the backside is a little messy.
Wow, I never knew it was that popular.Me. Another one who cut its teeth with the 1802.
Make your own jokes.the backside is a little messy.
The General Instruments PIC was also the controller inside the original Simon game. It took all 512 instructions to make it work. A friend from college got me a chip (40 pin DIP AFAIR) and the data sheet. I took it, two seven segments, 4 switches and a battery clip and wired it up and the dang thing worked!The PIC is a much older device that you might think - it started life as a support chip for a General Instruments processor back in 1976 - it stands for "peripheral interface controller" - and was originally fabricated in NMOS.
