[SOLVED] Stepper motors making high pitched noise (squealing/whining) and not moving, troubleshooting suggestions?
Adamelli
Joined Sep 14, 2020
66
I made a PCB. I have 12 V supplied to VMOT. A1 and B1 are both 12V. It's wired like the diagram.
Fault pin is 4 V which is odd. 5 V is supplied to the Arduino. The 5 V output is about 4 V which is odd.
The program runs perfectly fine on a previous version of the PCB. I adjust the potentiometer, and the noise persists. Any suggestions?
I also ran it at 24 V (VMOT). I've had the PCB double checked by someone else, and we both tested voltages. Everything looks good except for the fault pin.
34,700
Assuming that the hardware is not faulty, here are possible faults:
1) Connections to the motor windings A1, A2, B1, B2 are incorrect.
2) STEP rate is too high.
Try slowing down the stepping speed.
Adamelli
Joined Sep 14, 2020
66
I tried 1, 5, 10, 20, 50, 100, 200, 500, 1000, 2000 and some higher in microseconds:
digitalWrite(stepPinX, HIGH);
delayMicroseconds(5);
digitalWrite(stepPinX, LOW);
digitalWrite(stepPinY, HIGH);
digitalWrite(stepPinY, LOW);
It sounded slightly different with most delays. One stepper motor sounded like a slow/dying metronome. I'll try doing 500 microseconds and changing the wiring...
34,700
It would not hurt to start with a very long delay time, e.g. 2000μs. That should eliminate stepping speed problem.
Do you have access to an oscilloscope?
Adamelli
Joined Sep 14, 2020
66
These captures are from 2000 us. Same model stepper driver, but plugged in the same motor to a different driver on the PCB for the second scope capture.
ericgibbs
Joined Jan 29, 2010
21,419
hi Adam,
Is this PCB a different layout from the previous PCB that worked.?
Do you have photo shot of both the PCB's that you could post.
Mainly interested in the 0V ground tracks.
E
Adamelli
Joined Sep 14, 2020
66
Just added the 100 uF capacitor and flipped the driver module to the other side of the shield.
Edit:
The nRESET pin, when driven active low, resets internal logic, and resets the step table to the home position. It also disables the H-bridge drivers. The STEP input is ignored while nRESET is active. The nENBL pin is used to control the output drivers and enable/disable operation of the indexer. When nENBL is low, the output H-bridges are enabled, and rising edges on the STEP pin are recognized. When nENBL is high, the H-bridges are disabled, the outputs are in a high-impedance state, and the STEP input is ignored. Driving nSLEEP low will put the device into a low power sleep state. In this state, the H-bridges are disabled, the gate drive charge pump is stopped, the V3P3OUT regulator is disabled, and all internal clocks are stopped. In this state all inputs are ignored until nSLEEP returns inactive high. When returning from sleep mode, some time (approximately 1 ms) needs to pass before applying a STEP input, to allow the internal circuitry to stabilize. Note that nRESET and nENABL have internal pulldown resistors of approximately 100 kΩ. The nSLEEP pin has an internal pulldown resistor of 1 MΩ. nSLEEP and nRESET signals need to be driven to logic high for device operation.
ti.com/lit/ds/symlink/drv8825.pdf?ts=1629962860298#page=17
These default RESET and SLEEP states are ones that prevent the driver from operating; both of these pins must be high to enable the driver (they can be connected directly to a logic “high” voltage between 2.2 and 5.25 V
https://www.pololu.com/product/2133
ericgibbs
Joined Jan 29, 2010
21,419
hi Adam,
That PCB image is not helpful at all.
We need to see the tracks on both sides of the PCB.
E
Adamelli
Joined Sep 14, 2020
66
The solution was changing the direction and step pins (which I didn't do after flipping the driver modules to the other side on the PCB).
The correct test code:
Code:
const int dirPinZ = 3;
const int stepPinZ = 2;
void loop() {
    digitalWrite(stepPinZ, HIGH);
    delayMicroseconds(1000);
    digitalWrite(stepPinZ, LOW);
Thanks everyone.
