Hi there,
Please kindly read the problem here, I have not enough knowledge of electronics, your help is appreciated deeply
The Project
there is a room in the corner of an apartment, floor -1, there is no window possible there, I want to make an artificial light window in the absence of real one. that artificial light must turns on when sunrises in the morning and its intensity must increase up to the mid day then it starts to decrease until sunset it has to be shut down or almost off.
My Knowledge
I know a little bit in the term of electronics, for example I know that there should be a MOSFET in this project which its Gate has to be controlled by a light sensor, the MOSFET has to be suitable for 180 Volts DC (my SMD Diode strip specification).
The Problems
1- I absolutely do not know anything about how to choose that MOSFET!!!!! it seems there are a lot of different sort of MOSFETs.
2- How does the sensor actually should be set up to the MOSFET???
3- Anything I've missed???
Dear All readers, thanks for your patience, it is glade you've spent your time to read this, if you help me, then it will be much more awesome.
The Project
My Knowledge
The Problems
